ABeardedItalian
Flight distance : 1063107 ft
I think the bigger picture is being missed here, I think you can get similar data from all dji drones if you wish to.
That's great and provides the pilot with lots of information, how is this a bad thing that you can check with all drones? Are you saying all drones will have the "Same" data, to some extent they will but each model has a different size motor/prop that will produce different rpm's and will have a graph unique to it.
Since FW update we have not seen any involuntary drops including in all tests I’ve seen here, now I suppose we should ask why !
Involuntary drops weren't happening every day, we would go days between drop posts. With this new fw we have a new warning, that's what's cutting down on drop posts for the time being but for every person who ignores and goes back to 1.04 is just statistics waiting to be calculated.
Those who bypassed warning by simply restarting craft, those who updated through assistant, now maybe wait and see, according to you these craft will fall from the sky as blades new and old are according to you “even if the look fine” faulty so we should see plenty of craft falling from the sky or at least slowly going backwards and landing.
We shouldn't at all, remember my props never received the warning and are original. These are to be considered good but the RPM data shows that they are experiencing deformation and moving them to the front motors confirmed that. So if those rear props which never had the error in the first place, everyone would call them okay but I have the rpm information to say otherwise and why I created that thread. Just as you yourself have said "my props are fine" and if you looked at the RPM Data and seen the same as I did you would think everything is fine, but that's not the whole story is it. While the deformation is fine in the Rear, the clearance/tolerance of the front props is smaller and the deformation becomes evident only then.
It’s my belief that this prop warning was not the only improvement made to Mavic Mini to stop it from falling out of the sky and optimizations have been pretty evident to me.
I would really hope not, I wish they would tell us what exactly they did.
You know it’s really hard to accept that now we believe that props are faulty in such a way that we cannot see but users are prepared to continue to fly not knowing who has bad props and who doesn’t, I have not had any problems with my props I store in a way that has been frowned on here as a direct result of so called flattening props, yet my mini fly's fine. Last weekend I placed a prop under a 20kg steel block two days later I took it out and it wasn’t damaged and it wasn’t flat and it works fine.
Do they really work fine? All this talk but you don't show us any actual pictures or data outside of the props being stored. Your props could also not be fatigued as much as my props were/are. I would like to see that 20kg test again, with new props and old props. I bet the new props would hardly show any signs of change while the old/original props will show otherwise. Also from what I've read you only tried that prop on the Rear motor (I don't really know outside you switching one set from the front to the back) so there could still be more to the picture.
Now while I don’t believe bad batch of props bad plastic mix etc and flying drones for over 7 years, I have never heard or seen bad batch props with invisible damage and nobody here has proven this.
Things happen? I don't have an answer for this other then people aren't doing enough research. If I can't see the visual damage maybe I can another way, oh let's weigh them. My original rear props weigh .4 grams each and all combined weigh 1.6 grams, I weighed a fresh replacement set and each of those props weigh .55 grams and all 4 came to a total of 2.0 to 2.1 grams. So given how small these props are, losing material would explain why some props are weaker then others.
So I find it strange when someone with brand new props get warnings and by simply switching with another prop warning goes away but now can’t tell where the bad prop is now.
Props can get damaged deformed but they don’t grow bad .
They do if they experience material loss, bad manufacturing or QC but if one prop has less material it'll be under performing it's brothers.
What amazes me most that those saying that they might be flying with bad props accept it, I can just look at my props and I know they are fine.
I didn't know you had xray vision all this time. ![](//forum44.djicdn.com/static/image/smiley/emoji/13_2x.gif)
