A J
Flight distance : 14670299 ft
jdemay Posted at 5-16 22:41
Exactly, 700 meters (half a mile) is a really short distance for the comms to disconnect. I did one flights in the forest, (environment with virtually no interference), and I think the range was approx 2KM, again pretty disappointing results in terms, of range. I think I'm holding the controller right (towards the drone), in this model there are no antennas per say, they are built in the controller.
The MA2 RC uses a patch antenna and not the normal omni antenna as with the older Mavic RC's - the tip of the device holder needs to be pointed at the drone. There must be no physical obstructions in the environment that stands between the AC and RC to block the signal such trees (forests), hedges, buildings, cars, people etc - any object at all. The environment must also be free of interference that can impact the quality of the signal such as WiFi which is often found in or near congested areas.
Another consideration is what frequency you are using in the app. If set to auto the RC may auto switch to 5.8ghz if interference is detected - this tends to restrict the range of the signal. Try manually switching to 2.4ghz in the app, fly in the right environment if maximising your range is key and you should reach the max 6KM/3.7 miles in a CE compliant region such as the EU. (10KM is in FCC regions such as the US). Whether you would have enough battery power left for a safe return is another question and without being a kill joy - lets just say you won't be able to see your drone beyond a few hundred metres - at 6,000 meters... Let's hope there are no police nearby! |
