Mirek L
Flight distance : 609724 ft
JJB* Posted at 5-26 10:19
Yep, my experience as well if you update the HP (DJI Fly app, not the GoApp) without moving the craft on the map to a new position the update HP is where the craft is at that moment.
Guess i am 80% sure, will fly tomorrow and test it out to get 100%.
JJB,
I just tested it and here are my findings of what happens when you try to update Mavic Air 2 home point using DJI Fly app:
- Default, as you correctly suspected, is a current position of the AC (not RC).
- On the upper right hand side of a display there is a small two choice menu where you can switch between AC and RC as your home point.
- You can also drag an image of the AC on the map to show where the new Home point should be.
All in all this design is not bad. But lack of description of this in DJI Mavic Air 2 manual is simply sloppy.
I have only one problem with this design. The capability of dynamic home point updates according to the location of RC is missing.
This is something which should be available when you are moving (on the bike, car or in the boat).
And, of course, as discussed above, capability to choose "hover" as a low batter RTH option for active tracking.
Mirek
