Error landing
556 5 2020-6-5
Bloodjoker
I received an error message stating that the battery in my Mavic mini was too low, all in mid-flight. I tried to use the landing button, and the drone did the opposite: it started to gain altitude indefinitely! I had to hold the joystick down to hold it and possibly find a way to grab it manually ... How is this possible and how can it be avoided? Thank you!
2020-6-5
UKMoose
Flight distance : 3657552 ft
When you press the Home button the drone WILL rise to the set altitude that was set in the app before returning to home. IE if the drone was at 15mts altitude and the return to home Altitude is set to 30mts, when you press the Home button it will climb to 30mts before returning home and landing. Read RTH in the manual it's all there.
2020-6-5
JJB*
Flight distance : 12686732 ft
If you like help/explanation mayby....upload your log using this
link > https://www.phantomhelp.com/LogViewer/Upload/
cheers
JJB
2020-6-5
m80116
Flight distance : 3264131 ft
Because the landing button wasn't probably a landing button and was an RTH (Return to Home) button ?
The only landing button is a software button on screen.
2020-6-5
Bloodjoker
Thanks all,
the button was RTH button and not landing...
Thanks.
2020-6-6
JJB*
Bloodjoker Posted at 6-6 03:49
Thanks all,
Thanks.
push this btn once    and it will pause/cancel any action (cx quickshot mode, cx rth mode, ect)
cheers
JJB
2020-6-6
