customize/edit predefined story mode templates
20770 21 2019-7-10
MaxHH
Hi djiTeam,is it possible to customize predefined story mode templates?
I would like to extend time of the sequence and edit embedded text and its effects.
Which video editing/creation tool you have used for the templates?
Best regards
Max
2019-7-10
Snow2000
Flight distance : 24262 ft
I have the same question. I need to edit the text. It makes no sense to use the Templates with the embedded text.
2019-7-11
fans2b2df813
Same question for me
The embedded text is not applicable for my shots
Kind regards
2019-9-22
__balazs__
Hello!
The DJI Mimo app is pretty good, but the problem is that it can only shoot very short clips (in story mode).
Can you recommend me an (Android) application that can shoot a longer clip in the same easy way?
Thank you, Balázs
2019-9-23
GaRz
Flight distance : 1035653 ft
Still no answer?
2019-10-31
Sevrink
It would also be great to be able to design our own story mode templates by being able to add paths.
2019-11-3
fans8947b87a
I can’t get an answer from DJI either. Their email support is terrible, just keep asking for my Osmo serial number, what’s that got to do with it.
Better off using DJI go app of Quick app from go pro which is free
2019-12-11
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
DJI Mimo 1.2.12 already supports customize templates.
Story mode can select templates from mystory templates and customize gimbal movements:
To customize music or clips, you can edit the clips and music in Mimo editor and save as mystory template.
In storymode, you can choose the customized mystery templates and shoot a story.
2019-12-12
DjDaxx69
DJI-ytao Posted at 12-12 00:50
How do you remove the text that in custom mode?
2019-12-14
DJI-ytao
DJI R&D Squad
DjDaxx69 Posted at 12-14 08:58
it is not supported right now.
The work around way to is to setup a mystory template with same music and clips without text.
2019-12-14
kharisazhar
Indonesia
Me too.. please help me how to edit default tittle on default dji osmo pocket story like the Brisk one
2020-1-19
djiuser_3qFDYjbQyFzQ
I made my template with 40 shots on it but I can't use it. It says only up to 6. This is too few clips. Will this be fixed?
2020-6-6
Curt1591
djiuser_3qFDYjbQyFzQ Posted at 6-6 15:44
In the context of problems with the Pocket, I would have to guess "No".
2020-6-6
Suffering
Curt1591 Posted at 6-6 16:23
Then why add a feature that is not working?
Edit. I use this on osmo mobile 3
2020-6-8
Curt1591
Suffering Posted at 6-8 02:40
Sorry; you've lost me ...
2020-6-8
Suffering
Curt1591 Posted at 6-8 17:38
Why they added a so broken feature on the app
2020-6-9
Curt1591
Suffering Posted at 6-9 09:10
If you are referring to a 6 shot limit, that's not "broken"; it's simply their choice.
If that's not what you're on about, I'm afraid you'll have to explain a bit more.
2020-6-9
Suffering
Curt1591 Posted at 6-9 15:57
Hello
As it clearly sais it is currently not supported.  My question is if this will be fixed.
2020-6-12
Curt1591
Suffering Posted at 6-12 10:08
Hello
Let me look ....
2020-6-12
Suffering
Curt1591 Posted at 6-12 15:10
Let me look ....[Image]
Now i lost you!
2020-6-13
Curt1591
support@dji.com
This is the only place that can answer your question. Odds are they won't answer such a question.
2020-6-13
djiuser_xvfG6k53xh4q
Further customizion options for Story Mode seems like an easy thing for dji to implement.  Pleaser consider adding more options!
2020-11-9
