Forced landing over water: Never trust Battery %
4907 65 2020-6-17
trader6777
Almost lost my mini today.  RTH was activated at 73% remaining.
2020-6-17
Visual Air
Flight distance : 2710115 ft
That was a close one glad you made it.
2020-6-17
jonny007
Why not trust the battery indicator? RTH at 68% doesn't mean that that's enough for the same way back. Especially not when there is headwind on the return flight.
2020-6-17
ABeardedItalian
Flight distance : 1063107 ft
This is clearly operator error and not the fault of the mini, you were flying against the wind on the return causing the mini to use more power thus draining the battery quicker. Know the wind conditions before attempting something like this again, you might not be so lucky the next time.
Glad to see you made back safely, but you could of easily lost your mini.
2020-6-17
TDZHDTV
Flight distance : 2068550 ft
Warnings and messages are there to keep your Mini safe, why on earth didn’t you turn back when you got weak signal warning or at the very least lower your altitude?
2020-6-17
trader6777
ABeardedItalian Posted at 6-17 09:55
The video skips ahead, if you look closely RTH was activated at 73%.  So it used up 25% battery going out and 68% battery on the way back, that's a difference big enough to say, don't rely on the battery % to get back safely.   Also, I did my homework before I took off, wind was rated at 3.5 mph, at 380 ft, I'm pretty sure that was even close to accurate.
Bottom line, not operator error, battery % gave a false sense of security to fly out that far.
2020-6-17
trader6777
TDZHDTV Posted at 6-17 10:07
I will pay more attention to the warning in the future, because apparently, battery % remaining doesn't mean sheet.  RTH at 73% should have been plenty of cushion.
2020-6-17
JJB*
Flight distance : 12686732 ft
Why did the MM dit not RTH after 10 seconds?  as in 1m17 second in this video
2020-6-17
trader6777
JJB* Posted at 6-17 10:38
I cancelled  RTH when the video went blank.  My plan was, try for 15,000 ft, if I didn't hit it by 65% remaining, I would turn back.
2020-6-17
Andy Uk
Flight distance : 3985676 ft
trader6777 Posted at 6-17 10:18
Upload your flight data to AirData and you'll get more info back. Suspect it is headwind though what mode did you flight out using?
2020-6-17
trader6777
Andy Uk Posted at 6-17 10:41
Sport mode both ways.  I admit it was a mistake not lower altitude though.  The 3.5mph wind rating was for ground level and I need to keep that in mind for the future.
2020-6-17
JJB*
trader6777 Posted at 6-17 10:40
ok, what happend to your phone?  the Aircraft oreintation indicator turns red after while
and your mobile device compass is wrong or you have to turn your device 180 in the holder.
cheers
JJB
2020-6-17
Andy Uk
trader6777 Posted at 6-17 10:43
Big wind coming back then.  Don't trust wind forecasts look at your speeds at you alt and if you aren't getting what you expect bear that in mind.  You also kept pushing it well after the intial disconnect
2020-6-17
A J
Flight distance : 14754314 ft
Bit of a nail biting finish there - glad you managed to get it back just in time. Word to the wise - if conducting long range test flights in future always fly outbound into the wind then return with the wind speed carrying the drone (though wind direction can change). That will typically increase your air speed to be faster on the return journey and note that the drone does not take wind speed into account when assessing the telemetry to initiate low battery RTH. You were very, very lucky not to have lost it!
2020-6-17
3Recon
Flight distance : 4175541 ft
I know we've been in isolation for a long time but, testing out alt. and fight distance over water oh well but losing contact with phone!. The Mini lives to fly again. Give it a pat on it's back. it'll soar again. Enjoy
2020-6-17
Your big mistake was not understanding wind or your drone and thinking that a forecast is what the wind will actually be.
It's very easy to check wind speed and strength before you fly.
Wind will always be stronger up high.
The Mini gets 29 mph in Sport Mode in still air.
You were getting 18 mph.
That's telling you that you are fighting a 10 mph headwind up there.
And you stayed up high where the wind is stronger !!
If you're planning to go far, it's not a good move to fly downwind going out and force the drone to fight a headwind coming home.
2020-6-17
m80116
Flight distance : 3264131 ft
Also to be noted: the -battery level is low- notice has been disregarded. It's dynamic and can happen even with an almost full battery as it computes the distance the AC has to travel back to the homepoint.
2020-6-17
22340179
Flight distance : 6763835 ft
Don't do a range test in Sport mode. It uses more power. Weird how it lost so much power so quickly though, glad you didn't lose it. Would have been a stressful flight back to land heh.
2020-6-17
trader6777
22340179 Posted at 6-17 15:03
flying at a lower altitude is defiantly more efficient due to lower wind, but sport mode vs P mode... I don't think there's a notable difference in efficiency.  Do you have a data to back that up?
2020-6-17
22340179
trader6777 Posted at 6-17 16:05
It's tried and tested. Heaps of videos on youtube have a look. It uses more power over all over long distances.
2020-6-17
Paulaleroux
Flight distance : 28379 ft
I always wondered how folks got those shots.  Did you get that video from your Mavic Mini?  or were you recording your mobile phone screen?
2020-6-17
trader6777
Paulaleroux Posted at 6-17 17:08
Used the screen recorder that comes built into every iphone.  Video from the SD card is higher quality but won't display the flight data.
2020-6-17
Daniella3d
trader6777 Posted at 6-17 17:16
Not every Iphone. I don't have it on my Iphone 6.
2020-6-17
trader6777
Daniella3d Posted at 6-17 17:55
Nope, every iphone has it.  Here are instructions if it's not enabled on your phone:
2020-6-17
Daniella3d
I think you must have ios 11 installed. hmm I never upgraded my firmware. Last phone I did the upgrade, then it started calling every one on my contact list in the middle of the night, ramdomly.
2020-6-17
22340179
Daniella3d Posted at 6-17 19:09
Upgrading the ios on older devices can slow down older devices also. I have an old ipad mini that is basically useless because I updated it. Apple do it on purpose so you buy a new device.
2020-6-17
GaryDoug
Flight distance : 1264639 ft
I think your title of this topic is perfect. Might not be for the reason you thought though ;-)
2020-6-17
I think you were very brave doing a 15,000 foot flight out over water in a Mavic Mini, given all the shortcomings and issues the mini has.
2020-6-17
Very odd. pleased you got it back.
2020-6-18
ThalisGr
Glad you had your drone back. Not sure why you tried to fly it so far away though. I understand it was a test but what's the point?
2020-6-18
Daniella3d
22340179 Posted at 6-17 20:10
Yes they do it on purpose. We had 2 Iphone 5 and after upgrading to the new firmware, one of the phone started calling people ramdomly in middle of the night (not even during the day!) and then we replaced that phone thinking it was broken, then we upgraded the other Iphone 5 and it did the same exact thing, starting to call people on it's own in the middle of the night. They had removed the button to desactivate Siri as well, so no way to stop the phone from this programmed obsolete. I did a jailbreak and that took care of it! lol! Apple are crooks, now I do not upgrade the firmware at all unless it is absolutely necessary to install programs and I do a jailbreak instead of using the Apple firmware.
2020-6-18
Daniella3d
Geebax Posted at 6-17 22:13
I though the same thing. You were very very lucky to get your drone back. Amazing luck that everything went so well despite the 15,000' distance and the strong winds. That's amazing.
Like someone else said, it's always better to start the flight going against the wind, so when returning the drone it is going to be in the same direction as the wind and not fight it.
2020-6-18
BigBird-2
Flight distance : 883645 ft
Now that had me sitting on the edge of my chair. Glad you made it back safely.
2020-6-18
stuka75
Flight distance : 85682 ft
I wonder if that battery is at risk since it was nearly depleted to 0? Unless DJI has more battery capacity cushion that doesnt show on meters.
2020-6-18
Zen Fly
Flight distance : 981 ft
Romania
stuka75 Posted at 6-18 19:50
0 it's about max low level of discharge no 0v.
2020-6-18
Guorium
Flight distance : 513061 ft
The data is all over the place online. It is commonly accepted that lithium batteries dissipate more stored energy as waste heat when working at higher power output, for example pushing hard against strong wind on S mode instead of lowering attitude and use P mode.
2020-6-18
Ice_2k
Flight distance : 1132575 ft
Romania
trader6777 Posted at 6-17 10:14
Sorry man, your drone's speed on the way back shows 13-14 mph head wind. 100% user error, you're blaming the drone for no good reason. Also, seems really weird to ignore the battery warning (the drone notified you when you should start heading home) and then, when it turns out the drone was correct all along, conclude that you should never trust battery percentage
2020-6-19
AE1M
Flight distance : 1862884 ft
Looks like it worked perfectly, what’s your gripe?  You pushed your bird to the limit.
2020-6-19
Nolan Silvius
Flight distance : 238163 ft
I almost lost my mavic air 2 over water...but that was due to pilot error I ignored the low battery warnings and it started to land itself over water.
2020-6-19
Daniella3d
Nolan Silvius Posted at 6-19 04:25
is it possible to cancel an autolanding over water?
2020-6-19
