Clive Kennard
So I have seen a lot of posts WRT this "weak GPS signal" error using Apple products but I am having this exact same issue with Android:
As of 07/06/2020
DJI Mavic 2 Zoom, latest DJI GO 4 app and all updated firmware.
Samsung Galaxy S8 with latest OS/firmware.
Installed GPS status app on the phone just to check satellite connection and GPS status on the phone.
Ensured location is enabled on the phone and set to high accuracy (uses Bluetooth and WiFi a well as GPS signal for higher accuracy)
Standard RTH (from launch location) works perfectly every time but RTH to controller throws the ""weak GPS signal" error every time. Tried the unplugging micro USB lead at the controller workaround which does not work for me.
To be clear, the S8 has solid satellite connection with 12 or more satellites locked and lat/long of the phone acquired, despite this the controller disputes this fact with the "weak GPS signal" error so this has to be an error in the DJI app or firmware. Also tried using another device (Huwaei P Smart) with the same results - weak GPS signal so this isn't a phone issue. Not a cable issue either as I am using the stock cables that come with the Mavic (one USB C type on the Galaxy S8 and one micro USB B type on the Huawei PSmart).
Really frustrated that I can't get the Mavic to return to the controller location rather than the launch home point, mainly because I am a sailor and want to fly from the boat to get sailing footage, RTH to launch point would be disastrous on a moving sailboat.
Anyone else having this issue on Android devices with DJI GO 4? Any working workarounds/fixes?
When is DJI going to deliver an update that allows this critical piece of functionality to work?
