Mavic Air 2 Focus Track not activating while in flight
11855 28 2020-5-15
Malakai_UK
Flight distance : 536115 ft
Hey all, anyone come across this, i can activate focus track while the aircraft is on the ground by drawing a square around myself or an object. This enables Active Track in spotlight mode and i can then take off and it will track the object i selected. If i turn it off and try to track something else it doesnt work. If i just take off then try to select and  track something, again, it doesnt work. I came in to post this and decided to screen record this happening for a bit of extra context, now when i try and track on the ground it works, as soon as i take off it says im inside a geo zone. According to the maps and flysafe, im not. I checked if there was a zone or something to unlock in flysafe and theres nothing around me.
2020-5-15
Hi Malakai_UK, to use FocusTrack, you must take off and hover at least 3.3ft above the ground and then drag a box around the subject the camera view to enable it. How about re-installing the DJI Fly just in case the APP recognizes GEO wrongly. If it still doesn't work, any chance to share another video with the drone taking off?
2020-5-17
djiuser_4biF5KsB1p6l
My I phone 6 is not letting me draw a box around anything while in flight with DJI go newest app
2020-6-10
Acedog
I am also just outside a map restricted zone (maybe a couple miles).... same issue- drone is flying at 10 M height - try to select object - msg  shows about geo zone - then goes away and can't activate focus track.  But, as noted, if drone is on surface (not in flight) I can select a person and active track works.  But as soon as you fly and try to select another object it won't work.  Something in Geo is not allowing the option.  I see nothing in manual about active track in geo zone will not function.  I think the way the geo zone is mapped on APP must not align with the mapping screen showing the
position of unit relative to restricted zone.
2020-6-30
Uri
Israel
Acedog Posted at 6-30 16:58
Hi
Did you solve the problem?
2020-7-7
djiuser_hccVggruXoMv
DJI Mindy Posted at 5-17 05:05
My drone did this too. I called dji and they told me to send it in for repair. This was my first day with the drone. I returned the drone. I bought another drone and it’s coming tomorrow I’m praying to god that this doesn’t happen again. If it doesnt It was definitely a drone issue. If it happens again maybe it’s my phone. Or location but I’m curious to know if this is a known problem or issue with the drone that needs to be sent in for repair? Is this going to happen to me again?
2020-7-8
Did you find a solution?
2020-7-8
Malakai_UK
To be honest we havent really had the weather to test it in the garden again. I did however get a flight in while we were out exploring and the active track worked flawlessly. If its dry the next few days i might try it again in the garden.
2020-7-9
GaryDoug
Flight distance : 1264639 ft
I have used focus/active tracking extensively lately. I have been able to change targets very quickly. The only problem I have had is with fast moving targets, over 30 mph. Sometimes I make the box too large and it fails. I just have to make another one. I have noticed also that if it loses focus on the target, it often recaptures it shortly.
Something to be aware of however when tracking fast targets....sometimes the focus shifts to something else (like a wave) and the drone can go where you do not want it to go. I nearly ran it into a marina building once ;-)
2020-7-9
djiuser_hccVggruXoMv Posted at 7-8 15:07
Sorry for the late response, did you get the new drone? Does the issue persist with this one?
2020-7-12
righton
i have the same problem with mine. still trying to sort it out... it seems to work when it's really wide open space.
2020-7-26
KC_dronie
Flight distance : 95013 ft
I just bought a new Mavic Air 2 and I'm also having an issue where I can't get FocusTrack to activate at all.   I've tried taking the drone to the appropriate altitude, but I'm unable to select anything on the display.  I've watched a dozen videos and read all the support articles that I can find, but nothing seems to be working.  I updated the drone with the latest firmware, I also updated my phone and the app with the latest software/app versions.  I even tried a second phone, but no dice.  Any advice is appreciated.
2020-7-31
djiuser_UauCiVrUeMEO
Flight distance : 18428 ft
KC_dronie Posted at 7-31 06:51
Same here. Mavic air 2! No focus track period. Only way I could get it to to even allow me to draw a box was in QuickShots. The bar at the bottom with the option to chose from spotlight, active track....etc has never even been seen on my screen. Ive tried and watched all the videos as well. Nothing. It took two weeks for me to get receive it from DJI; I don’t want to go through that process again.
2020-8-1
KC_dronie
djiuser_UauCiVrUeMEO Posted at 8-1 11:28
Ok, I was able to fix my issue.  I downloaded Mavic Assistant 2 for my macbook, hooked-up my mavic 2 to my laptop, and reset the firmware.  That solved my issue.  FocusTrack works like a charm now!!!
https://www.dji.com/downloads/softwares/assistant-dji-2-for-mavic
2020-8-2
hardie42
Flight distance : 260531 ft
KC_dronie Posted at 8-2 20:06
Hi KC
What do you mean with resetting the firmware?
Downgrading and then upgrading again?
I have the same issue - NO focus track at all.
I can't draw the frame, no reaction of the app.
[EDIT]
Ok, I found it.
In the assistant there is a button 'refresh' - now I can draw the frame and - at least while being  on my desk -  the camera was following me.
Thanks KC for your description
2020-8-25
djiuser_KCMW99wnNwDO
Same problem.
Can draw the green frame around target when drone is on ground and gimble tracks. As soon as taking off I get a geozone message. If I try to draw the target box nothing happens except a “max distance reach” message.. Same message happens when trying to take panorama shot.
I’ve tried refreshing the firmware using the DJI Assistant 2 for Mavic as suggested by KC. Also tried downgrading firmware.
Neither worked for me, so I reloaded latest firmware.
I’m not inside a geozone according to DJI Fly app.
Did anyone find a solution to this problem?
Cheers.
Cheers
2020-10-11
Bob Gulliver
Exactly the same here... tried everything including resetting/ reinstalling the firmware on the Mavic Air 2 but still not able to select a target to use Focus Track once in flight. No green box and no identification of targets to select, nothing. The selection of a target works great when in Quick Shot mode, but not in standard camera mode. It seems a return is going to be required if I can't figure out something soon.
2020-10-14
Pilotfish
I sent in an enquiry through the fly app a week ago and haven’t recieved anything back.
I reloaded all the firm ware updates in sequence, and took my drone for a drive today out to an bush area complete free of aircraft, helicopters etc just in case I was in any hidden no-fly zone according to AIRMAP app. Still had the same issue. I will be taking mine back to place of purchase to see if I can get a replacement or refund. This is so frustrating. I bought the Mavic air 2 for its features and half of them aren’t working.
2020-10-17
idgibb
Flight distance : 49518 ft
Did you get this resolved?
2020-10-17
idgibb
Pilotfish Posted at 10-17 04:41
I am in the process of trying to figure this out. Let me know if you get this figured out.
Cheers
Ian.
2020-10-17
idgibb
idgibb Posted at 10-17 14:16
Cheers
I got active track working today. I went into my settings and adjusted the maximum distance setting and this seemed to fix the issue. My max distance was set to 30m and I adjusted it to 160m. Problem solved.
Cheers
Ian.
2020-10-18
Pilotfish
idgibb Posted at 10-18 10:30
Cheers
Oh my god! LEGEND! Thank you! FocusTrack now working too!!
2020-10-18
microadventurer
I had the same issue KC_dronie originally described above - the only difference, FocusTrack was working for the first 5 months of getting the drone and only recently started to fail. Reinstalling DJI Fly app on my iPhone did the trick for me.
2020-11-10
JohnLietzke
Flight distance : 3125968 ft
As mentioned in the previous post there is a minimum altitude requirement.  The Focus Track will clear any selected objects on take off or low height to ground.  It maybe tied to the bottom ground sensors or digitally in the app.
2020-11-10
JohnLietzke
You could test if it is the down sensors by covering them with tape.
2020-11-10
TomsToms
Same problem here. Fixed with firmware update.
My active track worked for 2 months then stopped sometime in the past month.
Worked as designed after update.
2020-12-3
JohnLietzke
Same here. It seems to be working since updating to v.0460.
2020-12-3
edurenye2
Since I updated my Mavic Air 2 to firmware v01.01.0610 and the controller to v02.00.1200, also I'm using a Huawei P40 Pro and I have the app updated to 1.3.0. The is no way for me to use the spotlight option, the active track and the POI work fine, is just that I can't select the spotlight. It was working fine before the update.
Also from before this update and is still a problem, I see that the active track loses track quite easily, more with a white background (snow). And since last update I feel like the active track follows me in a accelerate and break manner, before the tracking was more smooth.
I hope you can fix this small things for the next upgrade, after all I'm really happy with this product, you are doing an amazing work with it, thank you!
2021-3-31
JimDandy
Flight distance : 144649 ft
KC_dronie Posted at 2020-8-2 20:06
Exactaly what Mindy asked to have done in her first response to this post. Hopefully Malakai did the same thing. Glad to hear you have it functioning correctly!
2021-4-1
