gtokarsk
Flight distance : 14869882 ft
The settings on what to do when signal is lost are set from the app and transmitted to the drone when you make the setting change. Then it is up to the drone to enter RTH mode when it realizes it cannot talk to you, for more t6han 3 sec. Then your app will find out it's in RTH mode, once it gets in range and re-establishes connection. Then you can take partial control back, in RTH mode, or you can abort RTH and control it yourself again.
Does that make sense?
That is why when I set mine to hover on signal loss sometimes, means I actually have to get closer, and it will just wait for me till that happens. Could be bad if battery is low, as it would eventually start landing.. so RTH on signal loss is the best choice, unless you have a specific reason not to do it - like flying indoors, under trees or some structure, near or under power lines.....
Setting proper RTH altitude is quite crucial too. |
