Limited attitude 30m and range 50m
1196 21 2020-7-24
Sledz
Flight distance : 3333 ft
Dears, I’m new in drons – Mini is my 1st, Just piloted >20 flights and have permanent problem with limited attitude to 30m and range to 50m. Within or outside warning zone – same thing.
I’m logged in on DJI Fly app, I tried to find how to disable “beginners’ mode” – can not find it.
Any advice, please
2020-7-24
VanzPix
Flight distance : 229672 ft
Hello have you disabled the payload function in the dji fly app ?
2020-7-24
VanzPix
2020-7-24
VanzPix
sorry my app is in French
2020-7-24
A J
Flight distance : 14588274 ft
Are you in a geofenced NFZ? Is your drone on the current firmware? Are you flying with a mobile attached to the RC? Have you disabled the payload function?
2020-7-24
Sledz
VanzPix Posted at 7-24 02:34
yes, disabled
2020-7-24
Sledz
A J Posted at 7-24 02:38
I'm in Polish territory, firmware checked for updates and ok, nothing attached to drone I use IPhone connected to RC, payload disabled
2020-7-24
Sledz
Sledz Posted at 7-24 04:03
DJI Fly app gives warning (in yellow): that it limits attitude to 30m and range to 50m but not giving any reason/explanation for it.
2020-7-24
VanzPix
Sledz Posted at 7-24 04:11
or if not in safe flight protection: max altitude and maximum distance what did you put ?
2020-7-24
Sledz
VanzPix Posted at 7-24 04:17
Regardless what i put as limits – normally they are much more then 30 / 50m.
2020-7-24
VanzPix
Sledz Posted at 7-24 04:31
it's an idea but try to put flight and distance to the maximum and do a test
2020-7-24
VanzPix
Yellow Flashes four times Preheating.
Yellow Flashes Slowly No GPS or Vision System
lower (ATTI mode)
Yellow Flashes
rapidly losing the radio control signal
2020-7-24
A J
NFZ's refers to manned airspace i.e. within a certain distance of an airport.
2020-7-24
A J
Yellow means you are in an enhanced warning zone - that typically means you are able to take off but the flight may be restricted as you are too close to an NFZ. May be an airport, military base, prison, powerplant or some other sensitive area.
2020-7-24
A J
https://www.dji.com/uk/flysafe/geo-map
2020-7-24
VanzPix
sorry I misunderstood I thought it was the drone that flashed yellow. :/
2020-7-24
dronespilot
Flight distance : 1392995 ft
Did you fly with the propeller guard on? If yes, then the height and distance will be limited.
2020-7-24
Sledz
A J Posted at 7-24 05:12
normally yes but i also have same problem completely out of NFZ  checked on 2 different maps
2020-7-24
A J
Sledz Posted at 7-24 05:40
Generally the following will cause it - so check off each one to trouble shoot the problem:
-Flying in a restricted geo zone such as an altitude zone
-Flying with just the RC and no phone/tablet
-Flying in beginner mode
-Being on an outdated version of firmware whereby the latest version was mandatory to update
-Outdated version of the Fly app
-Using an older device that is not fully compatible
-Connectivity issues between the RC and device
-Having the distance settings set too low in the app
-Having the payload function enabled
or
-Malfunction with the drone - reinstall the app and refresh the firmware then calibrate the IMU and compass
If you have ticked off all of that and still experience the same issue then it may be best to return the drone to DJI under warranty for replacement. Good luck.
2020-7-24
Sledz
A J Posted at 7-24 06:28
Thanks to all of You, found solution! Inspired by 'Flying with just the RC and no phone/tablet' I have checked my Phone settings and set 'background App Refresh' ON - start to work properly now.
2020-7-24
A J
Sledz Posted at 7-24 11:49
Glad you sorted it
2020-7-24
Hi. Thank you for reaching out to DJI Forum. We are happy to know that your previous trouble was resolved. As AJ advised at post #19 the DJI Fly application maybe outdated, please make sure to always check for update as a part pre flight checklist. If you have further concerns or inquiry, please feel free to post it here at DJI Forum. Thank you.
2020-7-26
