EHEA
Flight distance : 363960 ft
Indeed, a data log would help. it should be noted tho that the max altitude of the MM according to the specs is 3000m above sea level, so while you were flying within specs, it‘s at least reasonable to believe that the drone is more prone to be affected by adverse wind conditions at 2300m,right? But again, the log will show whether the drone decided to descent for some reason, or whether it tried to keep the given altitude but was unable to do so. Or maybe the drone wasn‘t aware it was descending...all that could be true.
