Remote sometimes does not turn off
18767 11 2019-12-16
fans1646dc8a
Flight distance : 3179 ft
Hello Mavic Mini gurus!  I have a question: sometimes (maybe if I turn the aircraft off first?) I cannot turn off the remote control!  I do the short-click + long-click-until-all-leds-are-off but then the leds turn on again and sometimes the remote starts beeping.  It beeps for a while, then stops, beeps again, stops, etc. Then after about 5 minutes it shuts itself down on its own.  This is very annoying.  Any firmware update that can fix this?
2019-12-16
Hi. I am sorry to know that your DJI Mavic Mini Remote Controller is having issue. With regards to this concern.  I would recommend for you to do a firmware refresh for both remote controller and drone to isolate
the issue. If issue persists after the torubleshooting, kindly please post a short video of the said issue for further assistant. In addition, I will be posting a link ( https://www.dji.com/mavic-mini/downloads ) for the DJI Assistant 2 for Mavic and an official DJI video tutorial for the said process. Please keep us posted for further assistance Thank you.
2019-12-17
JodyB
Flight distance : 322005 ft
I always short press+long press not just until the lights go off on the rc but it makes a short series of beeps as well when it’s actually off.
2019-12-17
fans1646dc8a
DJI Paladin Posted at 12-17 16:07
Thank you.  I am in the newest firmware for both devices (and batteries).  I will see if it persists.
2019-12-17
fans1646dc8a Posted at 12-17 16:21
You are more than welcome and thank you for your valued support.
2019-12-19
djiuser_5lmYanAcclEP
DJI Paladin Posted at 2019-12-19 15:48
What was the solution for the problem, as I have the same problem. I can turn the rc off if I connect it to my phone. It would be nice if you would fix this issue as many may have the same experience.
2020-7-14
Sean-newbie
Flight distance : 15997 ft
The two button presses have to be quite close together, I find that if the 2nd press is at all delayed it will not switch either on or off.
2020-7-14
djiuser_5lmYanAcclEP Posted at 7-14 07:15
Hi, I am sorry for the trouble this has caused. With regards to this concern. Turning the remote controller on and off is the same step, double tap the power button but the second tap is held down until the remote turns off. Please refer to the image posted below for more information about the DJI Mavic Mini remote controller, if issue still persists, kindly please provide a short sample video of the issue. Please keep us posted for further assistance. Thank you.
2020-7-14
RTONE1A0L.COM
DJI Paladin Posted at 2019-12-17 16:07
i am having
2020-8-11
djiuser_fMuEUcQmlyx0
DJI Paladin Posted at 7-14 23:50
Turn the controller off before you turn the drone off.  That's what worked for me.
2020-9-28
djiuser_fMuEUcQmlyx0 Posted at 9-28 14:29
Thank you for the additional information. We are happy to know that your previous trouble was resolved. If you have further concern or inquiry, please feel free to post it here at DJI Forum. Thank you.
2020-9-29
Karmarina
djiuser_fMuEUcQmlyx0 Posted at 2020-9-28 14:29
Thank god for a simple quick solution. Thank you very much. I turned the drone back on and then turned the controller off before turning off the drone.That made all the difference and now the remote is off.
2022-6-25
