Throttle response
1047 9 2014-12-26
thomas.goring
After several flights, I  have no throttle response after engine start. Help?
2014-12-26
johnwarr
Flight distance : 6467 ft
Difficult to help without more information.
Have you changed anything since the last successful flight ?
Switched control modes on the transmitter ?
2014-12-26
thomas.goring
johnwarr@live.c Posted at 2014-12-27 04:51
Have you changed anything since the last successful flig ...
Good question. Only change I made was to replace SD card.
2014-12-26
johnwarr
What SD card did you replace the old one with ?
Not that it should make a difference.
Mode 1 and 2 can be switched in the RC assistant if you accidently click the wrong one, mode 2 is usual with the throttle on the left stick, mode 1 uses the throttle on the right stick.
2014-12-26
thomas.goring
johnwarr@live.c Posted at 2014-12-27 04:57
Mode 1 and 2 c ...
Replaced the original 4GB San Disk with a 32 GB Lexar. I confirm mode status. Thanks for the help.
2014-12-26
thomas.goring
thomas.goring@s Posted at 2014-12-27 05:02
RC assistant won't let me change the mode or calbrate
2014-12-26
rod
thomas.goring@s Posted at 2014-12-27 05:40
Do you have two little flashing lights at bottom left of the remote controller software? if not , you are not actually connected.  You will need to download the DRIVERS first, then the software..
2014-12-26
thomas.goring
that's the problem. RC system install v1.2 and DJI WIN Driver installer have been installed. Did I get it right? Thanks for the help.
2014-12-26
Gerry1124
thomas.goring@s Posted at 2014-12-27 05:58
that's the problem. RC system install v1.2 and DJI WIN Driver installer have been installed. Did I g ...
You also need the
DJI Phantom 2 Vision Assistant_3.6
2014-12-26
thomas.goring
Gerry1124 Posted at 2014-12-27 08:07
You also need the
For sure.thanks. I'm mobile.
2014-12-27
