Laowa 9mm for X7
3075 13 2020-8-4
nik317
Flight distance : 11261506 ft
I love that lense but why DJI don't support it?
2020-8-4
Matthew Dobrski
Flight distance : 1831050 ft
What to support? This is fully manual lens.
2020-8-4
Hi. Thank you for sharing these awesome photos you have captured. With regards to this query. Currently, the Zenmuse X7 is compatible with four DL-Mount prime lenses with a maximum aperture of F2.8. For more information please visit our official DJI Zenmuse X7 FAQ. Thank you.
2020-8-6
FVP
@Matt, you don’t know why we need manual support because you don’t have x7/Laowa 9mm.
When you work with X7 you can’t mount the Laowa like Dji lens. You need to power on you Inspire2 with a Dji lens and do a hot swap with Laowa 9mm. It’s not professional (like Dji products...)
We need the support of manual lens to avoid the hot swapping problems (dust on sensor, direct sun light on sensor, x7 drifting and calibration
You can’t record If you mount Laowa lens without hot swap...
Dji is not professional.
2020-8-14
Matthew Dobrski
FVP Posted at 8-14 03:11
Oh, I wasn't aware of such annoyance indeed, my bad. I have no issue mounting fully manual lenses on X5S camera ...
2020-8-14
FVP
X7 is different
2020-8-15
deniel
Flight distance : 105902 ft
Sorry what do you mean you can't use on x7?  I use it safely without any problem ... what problem does it have?
2020-8-19
FVP
No picture if I mount Laowa without hot swapping. Same thing on my two Inspire2.
2020-8-19
deniel
L'ho comprato e usato senza problemi sulla mia x7 ... impostato messa a fuoco e diaframma ... decollato e ho scattato video e foto
2020-8-19
Videocameraman
Flight distance : 289961 ft
I have a different issue. When I fit the Laowa to the X7 it switches my Cendence RC from PAL to NTSC and alters my frame rate and resolution to 4K!
2020-9-10
A J
Flight distance : 14670299 ft
deniel Posted at 8-19 12:36
Stunning images - thanks for sharing
2020-9-21
blander
Flight distance : 3076604 ft
Turkey
Videocameraman Posted at 2020-9-10 04:12
Hello, is there any solution for this issue?
2021-4-28
CR3
Flight distance : 5872635 ft
I just bought this lens for a shoot tomorrow and when i put on the X7 its terribly unbalanced, does this cause a problem and or how did people fix this?
2022-1-24
Coyut
Flight distance : 2559222 ft
CR3 Posted at 1-24 18:54
I 3D printed a large profile that goes over the lens and glued a lot of fishing lead in to balance it.
Otherwise its way to back heavy and will stress the motor.
2022-3-24
