jaboos
Neo Supreme Posted at 8-14 07:23
Okay, I don't really have to wait until tomorrow. I'm about 3 and a half hours into a time lapse, with my mophie power bank. It definitely will work with the OP, BUT, I periodically had to press the power button on the external battery to keep power to the OP, as for some reason, the OP causes the external battery to disengage. Probably because of the internal battery config of the OP. The external battery is indeed charging it though. Unfortunately, you can't just 'set it and forget it'. You'd have to be around enough, to make sure that the OP is getting a proper charge for the time lapse duration.
When I used it for those 8 hour long GoPro6 time lapses, I had taken out the GoPro battery, as the camera was not picking up the external battery.
So, at least with this specific Mophie brand external battery, internal camera batteries will negate it's effectiveness. I can remove the GoPro battery, which works for an unsupervised capture, but not with the OP.
Yeah this is problem. So for now, I can not see any way, how to leave OP on power bank for whole night (e.g. 10 hours) :/ |
