Blurry Photos with Spark
5693 11 2019-3-20
fansbdb41d8c
Flight distance : 143386 ft
Hi I recently bought my spark on when looking at the photos it looks really blurry and also blurry when zooming in. Am I doing something wrong or is that just how the camera is?
2019-3-20
fansbdb41d8c
2019-3-20
BRentAP03
Flight distance : 74872 ft
That has happened to me before, it only happened when I was moving around though, thats it.
2019-3-20
Hi, we're sorry to know about this situation. May we know if these images came from the SD Card of your aircraft? If yes, have you tried to reset the camera settings of your aircraft? I would like to clarify if this blurry would occur on the daytime or if there's enough light? The blurry image may occur when flying your drone in the night time or on a cloudy day. Within this situation. the blurry image cannot be voided, however.  this matter occurs when the exposure time is longer than 10 minutes. You can also set the camera to M mode to reduce the exposure time, but the image quality will decrease. For example, in A mode, the shutter is 100 and ISO is 100, then you can set the shutter to 200 and ISO to 200 manually. Please let us know the latest progress. Thank you for continued support.
2019-3-20
Rustic17
Flight distance : 2733760 ft
Hard to say...was it windy???  Also, check and see what the shutter speed is...all the shots are taken as the light is decreasing...you can display the camera settings on the Go 4 app so you can see before taking the shot what the shutter speed will be.  Anything less than 1/80 on a calm day and incrementally up as the wind increases might show some blurriness.  It's throughout the whole picture so it's not a lens aberation.  Try taking a shot on a nice bright day around midday...do one in auto mode and another in manual mode; then compare.
2019-3-20
Rustic17
Rustic17 Posted at 3-20 14:42
You don't really mean 10 minutes, do you Tony?
2019-3-20
Rustic17
Also check and make sure a protective film is not on the lens.
2019-3-20
nilanjan118
Flight distance : 636663 ft
Japan
Are you sure you have downloaded thee high resolution pics from the SD card mounted on the Spark? These look just like cache images stored in the mobile device to me.
2019-3-20
eYeSkYeYe
Croatia
Those look totally drunk to me.
Spark was FUI.
2019-3-21
Kevin Vun
Malaysia
DJI Tony Posted at 2019-3-20 13:43
I also got the same problem as him, but my photo is taken not from the sd card, is it better if i take the photo from Sd card?
2020-9-10
Kevin Vun
Malaysia
nilanjan118 Posted at 2019-3-20 15:57
I also got the same problem as him, but my photo is not taken from the sd card, is it better if i take the photo from Sd card?
2020-9-10
A J
Flight distance : 14588274 ft
Kevin Vun Posted at 9-10 23:16
Yes it is - the ones taken from the phone are cached files from the live feed so impacted with the quality of the WiFi transmission whereas the files from the micro sd card are straight from the camera.
2020-9-11
