FPV Distance Poor
1017 2 2015-10-8
swsamwall
Hi Guys,
I have installed the:
ImmersionRC Fatshark 600mW 5.8GHz TX (TX Aerial attatched)Black Pearl 7" FPV LCD HD Monitor with Built in Diversity Receiver 32 Channel 5.8GHz (RX Aerial attatched to port 2 and 5.8ghz aerial attached to port 1)DJI iOSD MINIH4-3d Gimbal Zenmuse with anti-interferance boardGopro hero 4 Black Edition
on to my phantom 2 this week.
i took it for a test flight tonight and all works fine apart from the range on the video feed that im getting.
once i reach around 100ft in both directions the video becomes crackly and bitty, sometimes lost all together.
can anyone help is there something im doing wrong?
i have it set to NTSC, band F and it picks up the picture on Channel 1.
2015-10-8
swsamwall
Update! I checked the frequency lost for both the transmitter and reciever and band F channel one is 5740 which is what the transmitter is, I noticed that the signal is poor at around 100-120m not feet. Coupd there be a problem with my  transmitter?
2015-10-8
hayen.dominique
Flight distance : 8117 ft
swsamwall@googl Posted at 2015-10-9 06:10
Update! I checked the frequency lost for both the transmitter and reciever and band F channel one is ...
did you fix the problem?
I have the exact same setup, except for the video TX. I use Flysight 700mW.
Before take-off I have perfect image on the Black Pearl.
Once I go airborn and 10m away, lot of interference (flickering screen)...
Greets from Belgium!
2015-11-5
