Cetaman
![](https://forum44.djicdn.com/data/attachment/common/4e/common_26_usergroup_icon.png) Captain
Flight distance : 2528264 ft
Aloha Butch,
Here may be the answer for your questions in the form of technicalities. On page 14 of the P3 manual in the middle of the page graphics for Failsafe RTH, graphics block 4 (out of 6) says "Signal Lost Lasts (after 3 sec.)". This means that if the obstruction is narrow enough for the P3 to pass behind it fast enough that it regains contact in less than 3 seconds, Failsafe RTH will not be initiated. The DJI video on waypoints (for the P3 Standard) says two things relevant to this discussion. One is that the highest waypoints speed (for the P3 Standard at least) is 5 meters per second. Therefore, the obstruction can be 50 feet wide.
And two - of the most interest - is that the waypoints video says in the beginning that the P3 can fly the waypoints autonomously - which means independently, as in no controller needed. This means that if you can get around the obstruction well enough to set waypoints on different sides of the obstruction; and you can fly above and far enough behind the obstruction to determine that there are no obstructive problems behind the obstruction in a straight line (or lines) between the set waypoints; then according to the video, your P3 should be able to connect the dots. This also indicates that as long as the battery holds out (the only thing said in the video about RTH), the P3 will go around obstructions wider than 50 feet - even much, much wider. The video signal will be lost of course, but many pilots disable the tablet / phone video cache for performance stability anyway. All the video is on the SD chip. You also would not be able to fly the waypoints route with "free" control of the camera because there would be no communication, so you would have to set the waypoints real well.
This information might solve a problem some day, but it needs to be tested and confirmed. If I could find an appropriate obstruction (50 feet wide and another wider), I would give it a shot, but everything here is mountains, valleys and jungle or else there are too many people around. Got to think about this some more.
Just sayin.
Aloha and Drone On! |
