H20T R-JPEG Images
24425 42 2020-7-10
JonoMcG
Good day All,
I've been working on trying to decode the R-JPEG images captured by the new DJI Zenmuse H20T thermal camera so that one can extract the temperature information from the images without needing to go through DJI Thermal Analysis Tools.
It seems crazy to me that DJI has not provided any way for a user to even export the actual temperature measurements for each pixel from their software into a different format (like a .csv or .tiff). The DJI Thermal Analysis Tool is extremely basic and very limiting for any proffessional inspection reporting using the thermal images.
I've managed to figure out that the raw thermal sensor values are stored within the APP3 segment of the Jpeg image as 16-bit unsigned integer pixels. I can export this out as a 16-bit .tiff image. However, these values are only the raw sensor values and does not give one the actual temperature measurements (the values in this image range from 18073 - 21222). Whereas when the same image is opened in DJI Thermal Analysis the temperatures range from 7.5°C to 27.7°C (depending on settings for emissivity, distance etc.).
Flir uses a formula like this to convert the raw sensor value to temperature: Temperature (in Kelvin) = (B / Log(R1/(R2*(S+O))+F))
S = 16 Bit Raw sensor value
T = object temperature in Kelvins
R1 = Planck R1 constant
R2 = Planck R2 constant
B = Planck B constant
F= Planck F constant
O = Planck O (offset) constant.
The specific calibration data above can be decoded from the Flir R-JPEG file using ExifTool. The guys there managed to reverse engineer the Flir format.
It seems like there could be some calibration data stored within the APP4 segment of the image. I am hoping that if we can decode this we would be able to use the calibration data to correct the raw sensor values to give actual temperature readings. Unfortunately my experience with reverse engineering binary data is next to nothing. Is there anybody else who has experience or any ideas with how to retrieve the calibration data (and subsequently the temperature info) from within the image?
On another note if DJI Support can give any insight into whether they have any planned support for getting the temperature information out of the image any other non-proprietary format?
I've uploaded the original H20T R-JPEG image as well as the converted raw sensor 16-bit .tiff image to the following OneDrive folder for anyone who wants to download and play around with it: https://hawk62aviation-my.sharepoint.com/:f:/g/personal/jonathan_hawk62aviation_onmicrosoft_com/ErzBhLPJjKpLvljPM6k6d4gBCm6gjeZNPjLBF7LS8_0Vaw
2020-7-10
rdosdcuatrogmail.com
hi JonoMCG unfortunately I have the same problem, DJI's solution is to wait for a terra update.  Have you been able to advance any further on this topic?  Who do you think could help us?
2020-7-10
I cant download the image not show link.
2020-7-10
JonoMcG
I've posted the question on ExifTool's forum: https://exiftool.org/forum/index.php?topic=11401.msg61059#msg61059. They are the ones that managed to decode Flir's R-JPEG images so I'm sure they'd be able to do the same for DJI's R-JPEG images. I haven't had any more luck decoding it myself. Hoping somebody with more experience will jump on board.
Find it very frustrating that DJI would limit the use of their professional thermal camera so much. It's also very misleading to people to openly advertise that it is radiometric without letting people know that you cannot get temperature information out from the images except when looking at the images in their very basic and poorly designed DJI Thermal Analysis Tool.
What exactly did they say about Terra? Are they planning to allow users to convert the images from within Terra or only view them similar to the DJI Thermal Analysis Tool?
I've also updated the link in the previous post. It should work now. If not the images can also be downloaded from my post on ExifTool's forum.
2020-7-10
They want to improve DJI thermal analisis tools and add in terra an option to perform orthomosaics.  I count myself as your frustrated.  the camera is awesome and works really well but without being able to export images you cannot get its full potential.
If you want add me to telegram  @SamyNeutron
2020-7-11
AndreTaps
Hi Guys,
I can now convert the R-JPEG images to .tiff. You can send me a personal message for more info.
Cheers
2020-11-19
MW_POE
We would like to connect with an active developer community for the m300 platform. We need custom software including thermal analysis as you discussed. If interested message me. Let’s start a sub message group perhaps.
2020-11-20
fans663a4b75
Flight distance : 52 ft
Please help me too to convert R-JPG and use into pix4d or metashape.
2020-11-28
DrMrdalj
Flight distance : 1265978 ft
Serbia
Would anyone be so kind to share info on exporting M300 RJPG inspection findings in any report other then an screenshot?
2020-12-2
DrMrdalj
Serbia
I am VERY disappointed with all the software and marketing decisions in Enterpise and Agriculture DJI platforms - H20T “radiometric” capability is the last example... There is no export option in DJI Analysis Tool, there is no TIFF in recording options... in many ways it is step backward from XT2 if you are not exclusively  into security.. Onother great example is that T16 and T20 spraying drones can not import KML or any other external mission geometry (not even plot boundary) and there is no such option even in DJI Terra - all spraying missions has to be drawn by hand in the app or “automatically” in the Terra.... Even when mission is automatically created there is no inspector tool for waypoints, so you can dread the altitude/height of the waypoint...  Then, if you happen to use P4RTK or M210RTKv2 there is full KML support for mapping missions
So many gotchas that seem intentional...
2020-12-2
JonoMcG
RE: H20T R-JPEG Images
DrMrdalj Posted at 12-2 18:08
Good day All,
I have created the following  Windows command line tool that I use to convert the DJI R-JPEG images to .tiff temperature images (similar to the FLIR tiff format). The temperatures within the converted tiff images are equal to the pixel value / 10. You can use these images within Agisoft or Pix4D to process radiometric thermal orthophotos.
You can download the utility from the following OneDrive link: DJI H20T command line converter
There's a README file within the folder that gives you instructions on how to run it. It's a bit of a hack but it has been getting the job done for myself. The code is created from reverse engineering DJI's Thermal Analysis Tool. Anyone can read me about the source code / methodology on the following ExifTool forum thread: Exif Tool Forum Thread
Feel free to get the source code and improve the utility from the above Exif Tool Forum.
2020-12-3
fans48c0c119
Flight distance : 250459 ft
JonoMcG Posted at 12-3 09:21
Good day All,
Hello!
Your tool looks pretty good. I will test it more, but I have a question. Is it possible to convert not just a single picture but a whole folder at the same time?
Thanks in advance!
2020-12-10
JonoMcG
fans48c0c119 Posted at 12-10 10:09
Hello!
Not directly using the command line tool at the moment. I use the command line tool within a python script to iterate over a folder of images, exporting out each image individually:
For example:
import subprocess, osdirectory = "." #current folderfor root, dirs, files in os.walk(directory):   for f in files:
      if f.endswith("T.JPG"):
         file_path = os.path.join(root, f)
         p = subprocess.Popen(['C:\dev\Python\DJI_R-JPEG-converter-cmd-tool\dist\main\main.exe', '-o', folders['thermal_tiff'], file_path])
         p.wait()
It wouldn't be difficult to modify the command line script to be able to do this. I don't have time at the moment but anybody else is free to do so and share the modified version. All the python source code is shared on the Exiftool forum: https://exiftool.org/forum/index.php?topic=11401
2020-12-11
dseguradogmail.com
Flight distance : 1640 ft
Peru
AndreTaps Posted at 2020-11-19 02:24
Hi Guys,
Heyy Andretap!! Can you help me? I need to convert as well the format to .tiff
My email: david@linnaero.com
Thank you so much!!!
2021-1-3
djiuser_hJNGGpRe8Isr
JonoMcG Posted at 2020-12-3 09:21
Good day All,
Hi Jono,
Thank you for creating this tool! I've just been testing it on my H20T images and have encountered a problem on my end. I ran the code (screenshot attached), and from the input image (screenshot attached) I have generated a blank image (screenshot attached).
Are you able to tell me what I am doing wrong here?
Thanks!
Elie
2021-2-8
EDIT: opened in ArcGIS and can read tiff files. Thanks!
2021-2-8
JonoMcG Posted at 2020-12-11 00:57
For example:
Hi Jono,
Your script for extracting temp data from H20T photos has saved my life! I'm trying to use your python script for batch processing folders but can't get it to work for me. I am not too knowledgeable about python, I was wondering if I'd interpreted your code correctly?
import subprocess, osdirectory = "path to "main.exe file" :   for f in files:
         p = subprocess.Popen(['path to main.exe file', '-o', folders['thermal_tiff'], path to input photos])
         p.wait()
Is this correct?
2021-2-9
CHEW_33
Japan
Good day All,
Hi, thank you very much for your efforts. I have tried on using your DJI H20T command line converter but I have been returned with failed execution message. Would you advise me on this error?
2021-3-11
MMD
Flight distance : 106631 ft
Serbia
I have problem running the script in cmd. When i run the command line i got message "Thiss app can't run on your PC..." can anyone help me with this?
2021-4-20
Zeke13z
Hi @JonoMcG!
After seeing your reply to DJI stating the M2EA images were similar to the H20T in their formatting, I was wondering if you had made any changes to the software you have created to accommodate the M2EA?
Second and the reason I'm asking the above question: I downloaded your tool and attempted to use it with the M2EA images and received this error. Would you have any idea what might've caused this?
2021-4-20
JonoMcG
Zeke13z Posted at 4-20 13:40
Hi @JonoMcG!
Hi, no unfortunately not yet. It looks like the R-JPEG image format stored by the M2EA is of a completely different format to the H20T images. The .dlls used to do the conversion is different and therefore the utility I made won't work on the M2EA (same as the old DJI Thermal Analysis Tool).
DJI has released a new v2 of their Thermal Analysis tool that is compatible with the M2EA. This tool seems to use different .dlls to do the conversion of the M2EA images. If I find the time I might try look into doing some reverse engineering on the v2 Thermal Analysis Tool to see if I can figure out the function calls and parameters that are made to this .dll to be able to convert the M2EA images. If anybody else on this forum has time or experience in reverse engineering I'd appreciate the help..
Alternatively DJI has stated in an email to me that they will make their Thermal SDK (TSDK) compatible with the M2EA images in the future. No timeframe given though. Once they release the Thermal SDK one would be able to do the conversions though and I'd be able to update the utility.
2021-4-26
JonoMcG
For anyone converting H20T or XTS images and running into issues with my old script: DJI has released a Thermal SDK that makes these conversions fairly easy.. I'd suggest switching to using their official SDK to do conversions to the R-JPEG images for these cameras.
https://forum.dji.com/forum.php?mod=viewthread&tid=230321
2021-4-26
Zeke13z
JonoMcG Posted at 4-26 00:24
Thanks for the reply Jono. I'm sure I (or other members from here or other groups) would be more than willing to send you some photos if needed.  The work you're doing is incredible for this community.  I'd love to help, but that's unfortunately not my area of expertise.  I will be following.
2021-4-27
iidancom
Israel
I am comparing the values I get from the tiff with what DJI therml analysis tools provide and there are significantly different
I can provide the samples
my mail is i@idan.com
Joe
2021-7-18
djiuser_UDfpmmQJw2DY
Hello everyone,
I need to convert images acquired with my h20t camera but I can't...
I used different scripts but I always have the same result.
I also used the scripts of exiftool forum.
All time, I have a black image in output, would you have an idea to help me? Thanks!
2021-7-23
djiuser_3D8kpKM33jRl
Oman
JonoMcG Posted at 4-26 00:28
Could you please share the link of dji sdk
2021-7-23
djiuser_kMIg5993HklS
djiuser_3D8kpKM33jRl Posted at 7-23 03:50
https://www.dji.com/downloads/softwares/dji-thermal-sdk
2021-7-23
Bruno SDS
djiuser_hJNGGpRe8Isr Posted at 2-8 19:37
Hi Jono,
Thank you for creating this tool! I've just been testing it on my H20T images and have encountered a problem on my end. I ran the code (screenshot attached), and from the input image (screenshot attached) I have generated a blank image (screenshot attached). [view_image][view_image][view_image]
Salut, problème similaire pour moi, c'est à dire une belle image noire. C'est vraiment frustrant !
Je désespère de pouvoir utiliser les images en rjpeg de la H20T.
Si quelqu'un à une solution à proposer, j'en serai ravi .
Merci par avance à la communauté
2021-7-25
Bruno SDS
Hi Jono,
Salut,
si tu obtiens cette image noire, c'est tout simplement un Tiff qui n'a pas de prévisualisation. Pour voir si ça fonctionne, ouvre ton fichier sous Qgis ou autre logicel de SIG en mode raster. Nornalement tu devrais obtenir une image en niveau de gris
2021-7-31
GeoFlow
Hi Jono, thanks for the information and your script. But the two things are not comparable. Your script is much better than Thermal SDK from DJI. With Thermal SDK you can't create TIFF files, can you? I always get only an export in RAW format. How do you process these RAW files? Can you simply convert them into a TIFF format? All my post-processing (python) is based on the availability of TIFF files.
2021-8-6
djiuser_xKUQu5ufzV4i
Any news on getting SDK to support Mavic 2 Enterprise Advanced?
2021-10-26
hoss_
Flight distance : 166168 ft
djiuser_xKUQu5ufzV4i Posted at 10-26 04:36
Here is a link to the beta: https://drive.google.com/drive/f ... _b31p1J?usp=sharing
2021-10-27
Guillaume89
Flight distance : 270476 ft
Martinique
Good day All,
Hi thanks a lot for sharing this tool.
However, when I run this command, the created tiff files does not contain any location information, do you a tip about it ?
Regards,
2021-11-16
Billa0608
Hi, I've problem compiling the SDK and the download link for DJI command line tool is not working. Any help would be highly appreciated.
2021-12-29
Mayotte Drones
Flight distance : 925331 ft
Guillaume89 Posted at 2021-11-16 07:38
Salut Guillaume,
Tu as trouvé une solution à ton problème ?
Convertir les RJPEG en TIFF pas de soucis mais je perds toutes les données GPS aussi...
Merci pour tes lumières ;-)
2022-1-19
mac230
Flight distance : 80062 ft
https://aetha.global/product/thermoconverter/
2022-1-26
SpeedyPhire
Flight distance : 164747 ft
I have been working on a software package to do the sorts of things you are talking about.  It is designed to analyse a directory full of R-JPEGS and identify the temperature limits which can then be searched using a temperature range the culled set can then be displayed for further analysis.  The code to get float values is:
First load the data into an internal buffer by whatever method you are using, then you call dirp_create_from_rjpeg to set up the dji data structure.
                if (dirp_create_from_rjpeg(_filedata, _filesize, _handle) != DIRP_SUCCESS) {
                        MessageBox::Show(L"Failed to create DIRP Handle.");
                        return DIRP_ERROR_NOT_READY;
Determine the framesize.
                dirp_get_rjpeg_resolution(*_handle, _resolution);
                _framesize = _resolution->height * _resolution->width;
In reality this is a constant but has been written to allow for change later if required.
Then allocate an array of floats that are the size of the frame:
        if ((_floatdata = (float*) new float[_framesize * sizeof(float)]) == nullptr) {
                                        MessageBox::Show(L"Unable to allocate memory for float data.");
                        return DIRP_ERROR_MALLOC;
Then you can convert to floats by using:
                if (dirp_measure_ex(*_handle, (float*)_floatdata, _framesize * sizeof(float)) != DIRP_SUCCESS) {
                        MessageBox::Show(L"Unable to allocate create float array.");
The above is a bit clunky and will be improved at some point but does the job for now.
If you are interested in my work let me know.
cheers
Paul
2022-1-27
djiuser_xXMh5LiOKbjM
Good day All,
Thank you for creating the program to convert R-JPEG images from the H20T camera to images with temperatures.  I would like to test this program. However the link to the SharePoint doesn't work... I don't understand why.  Would it be possible for you to share the program's link .  Thank you in advance for your help.
2022-2-4
sunbox
Japan
Good day All,
hi
i use h20t data in pix4dmapper,but data need convert
this link is lost,could you please update DJI H20T command line converter ?
thanks
2022-2-7
fansc21abebd
Flight distance : 925010 ft
I can’t make R-JPEG with the M2EA
2022-7-4
