Aircraft orientation
1502 11 2020-12-30
fans745dc953
Flight distance : 76198 ft
I’m fairly new to the mavic mini. Been flying for about s month with no problems. One day the aircraft orientation in the bottom central of the DJI fly app just disappeared, I tried all the settings, I re downloaded the app checked for firmware updates. How to I get the aircraft orientation back??
2020-12-30
Bussty
Flight distance : 320951 ft
This might help...
DJI Fy would have updated to 1.2.2 and that has the changes. Assume you are on IOS?
2020-12-30
GaryDoug
Flight distance : 1264639 ft
1.2.2 for Android has been available for days now, just not on Google Play.
OP, you do not get it back. It was replaced by an inferior version.
2020-12-30
reguza64
Flight distance : 60375420 ft
Indonesia
GaryDoug Posted at 12-30 19:29
For me still no good design, I have tested on android. The good one is from GoApp radar, HP at the center and aircraft going out.
2020-12-30
fans745dc953
Bussty Posted at 12-30 18:54
This might help...  https://www.youtube.com/watch?v=ORbSTt3Ht1M&feature=emb_title
So this replaced the semi circle on the bottom center of the screen, I didn’t upgrade my firmware until after it disappeared,
2020-12-30
Hello there. Thank you for reaching out and for these information you have posted. For additional reference I will post the the meaning of each icon as follows:
Blue arrow: Where the Aircraft nose is facing
Green Light under Blue Arrow: The direction of the cradle head camera
White N icon: Due north
Yellow H icon: Return Home Point position
Blue dots: Mobile device location; The triangle icon points to the orientation of the remote control (mobile device compass)
Two white lines:  refers to the plane's attitude, the fuselage leans forward, the white line is tilted to the upper part of the attitude ball, the fuselage leans left, the white the line is tilted to the left of the attitude ball; When the fuselage leans forward perpendicular to the ground white line reaches the top of the attitude ball.
(1) The proportion of the white line to the attitude ball represents the forward and backward tilt Angle of the aircraft.
(2) The left-right tilt degree of the white line represents the left-right tilt Angle of the aircraft.
What is the center of the attitude ball?
The center point of the attitude ball is the position of the aircraft.
Thank you and fly safe always.
2020-12-30
fans745dc953
DJI Stephen Posted at 12-30 21:43
Too complicated, the semi circle was simple & easy, I just want to know the direction my drone is facing, any way of rolling back the firmware??
2020-12-31
jonny007
Firmware ? More likely the app, uninstall the current, install an older one.
2020-12-31
fans745dc953
jonny007 Posted at 12-31 09:27
I’ve all ready tried that. My iPhone 8 tells me that the app isn’t trusted & won’t let it install
2020-12-31
Donut
Flight distance : 42415 ft
That was very helpful.
What is the in lower left for.
2020-12-31
cLaNzKiLLeR
Flight distance : 1360007 ft
Malaysia
Hope this animated + real time video can help to visualize and understand it better.
2021-1-6
Adrian_here
Flight distance : 1322 ft
I had the central orientation display and then like you found it had just disappeared. Having had a look at the replacement display the only way I can get to grips with it is to imagine myself in the drone looking out from it, rather than viewing the drone from the controller/home point. I wonder if it would have been better to place the controller/home point centrally and then have the drone moving around in the circle?
2021-1-25
