Lost connection on return to home mode and flight away
4054 51 2021-1-9
jcp_eu
Flight distance : 65269 ft
On RTH mode, after about 10 seconds, I lost connection to my mini 2,  it flew away to another direction (there wasn´t wind) and crash on the woods, impossible to get it back, i could not found it yet.
I share my flight log because I need to know if I did something wrong or it was a DJI mini 2 software failure
Flight log: https://www.phantomhelp.com/LogViewer/TPO8PIWTO0HYO7GK9X5C/
2021-1-9
Your flight data isn't much help.
It shows you flying 160 metres away and initiating RTH.
The drone started coming home and got to 108 metres from the home point when the data stops.
If the drone just lost signal it should have continued coming home.
If there was a hardware failure or loss of power it should be around 43.16806  -8.17732.
2021-1-9
jcp_eu
Labroides Posted at 1-9 03:43
Thanks!, As soon as I got the signal lost alarm I could see the mini 2 going to the opposite direction at full speed, lose sight of it and I could hear the collision with the trees, but I can not find it.
The possition where I got the signal lost alarm was more near home than the flight data registered
2021-1-9
jcp_eu
Well, I had to use a pair of binoculars but finally found it, it was on the top of one of the trees, and when I finally got there the mini fell down and I could catch it, lucky me!.
It didn´t have the battery so I had to search for it around half hour until I found it
A explanation map:
2021-1-9
sbonev
Flight distance : 3665279 ft
you were on a lower ground flying uphill, but still 100 m up and end up on a tree seems strange. were those trees any high? or it just crash landed?
2021-1-9
jcp_eu
sbonev Posted at 1-9 04:39
Thanks sbonev!, the trees have a height of 20-30 meters (around 65-98 ft)
As I said before, when I recived the lost connection alarm the mini change to the opposite direction at full speed
It´s very strange ...
2021-1-9
AntDX316
Flight distance : 3394731 ft
jcp_eu Posted at 1-9 04:58
What phone are you using?
2021-1-9
jcp_eu
AntDX316 Posted at 1-9 05:09
a Samsung Galaxy S10 Plus
2021-1-9
AntDX316
jcp_eu Posted at 1-9 05:11
You need to analyze w/ another software to see everything.  Ask DJI to analyze it.
2021-1-9
jcp_eu
AntDX316 Posted at 1-9 05:17
Thank you for your reply!
2021-1-9
Hi, jcp_eu. Thanks for reaching out and we're sorry to read about the unfortunate event you just experienced. Since you're able to retrieve the unit, we strongly recommend returning it back to our Service Center so we can assess if there are any damages to it and also conduct a Data Analysis to give enlightenment about what happened. At your soonest convenience, please get in touch with our Customer Support to assist you to open a ticket.
2021-1-9
George GR
Flight distance : 2990653 ft
Hello jcp_eu,
you had an old version 1.2.1 ios
last version ios 1.2.2 here https://www.dji.com/gr/downloads/djiapp/dji-fly
https://airdata.com/
2021-1-9
jcp_eu
George GR Posted at 1-9 05:49
Hello jcp_eu,
Thanks for the info!, but the phone is an android and the last version is 1.2.1
UPDATE
The last version for android on Google Play store is 1.2.1 that is older than the APK on the DJI website
Thanks again!
2021-1-9
George GR
jcp_eu Posted at 1-9 05:56
last version 1.2.2 android https://service-adhoc.dji.com/do ... 2-b4ab-9cf977d77309
2021-1-9
jcp_eu
George GR Posted at 1-9 06:17
last version 1.2.2 android https://service-adhoc.dji.com/download/app/android/3b03cb95-bc4b-4b62-b4ab-9cf977d77309
Yeah!, I downloaded the Google play store version (1.2.1)
Thanks again!
2021-1-9
George GR
jcp_eu Posted at 1-9 06:20
Thanks again!
download the latest version from the link I sent you
2021-1-9
jcp_eu
George GR Posted at 1-9 06:26
thanks!!
2021-1-9
George GR
You're welcome.
2021-1-9
Suren
Flight distance : 13498560 ft
I doubt the app version will be in any way related to the crash, you need to get Dji to analyse the crash data or if can get the .dat file from the phone logs post on here and maybe JJB can look at it. It is really strange for the drone to go in the app direction in RTH mode on signal loss. It could be that it does the flight path retrace on signal loss and your RTH height was set lower than the height of the trees hence the crash!!
2021-1-9
jcp_eu
Suren Posted at 1-9 12:06
Before the flight I changed the maximum altitude to 100 meters and the RTH option changed automatically to 99 meters.
This screenshot (sorry for the quality ...) was taken from one of the videos that was recorded, I have marked the crash zone, way below of the RTH altitude:
This link is the return video, on 00:37-38 I pressed the RTH button, the video ends before the point of signal loss: https://streamable.com/zsacum
2021-1-9
sbonev
jcp_eu Posted at 1-9 12:51
well but the conditions seem foggy and snowy. what temperature did you have. most probably ice formed and could have caused the drone to lose altitude. though there should be errors in the log
2021-1-9
Donut
Flight distance : 42415 ft
sbonev Posted at 1-9 12:55
One thing caught my eye.
1. Did the SD pop loose and was it in till it locked in.
2. You said you couldn’t find the battery. Was the battery clicked all the way in. If it  wasn’t then it could have moved back and disconnected and  bumped the door and open and fallen out.
That could have caused the sudden disconnect.
I’ll let the pro’s her do their thing.
Doug.
2021-1-9
It's not strange ... it's impossible.
On losing connection, RTH would have continued.
It wouldn't have changed direction and flown off somewhere else.
The drone was well above tree height and wouldn't have collided with trees n RTH.
The only explanation that fits the data is that the indication of loss of data was due to the drone losing power and falling from the sky.
This also explains how the drone came to be in the tree.
The firmware version has nothing to do with the incident.
But if you had been using V1.2.2, much of the flight data would have been unreadable.
2021-1-9
Monkey007
Flight distance : 73775046 ft
Donut Posted at 1-9 13:10
Isn't the micro SD card slot on the mIni2 located outside the battery compartment???
2021-1-9
Donut
Monkey007 Posted at 1-9 13:46
It is. But he said it flue into a tree. What if it lost connection on the SD card. Not saying he did.
If it was doing a RTH and lost battery connection above the tree and came out above the tree then fell to the tree.
If the battery was still in wouldn't the find me option be working.
It’s like it had a sudden loss of power. If the battery wasn’t clicked in. ???
2021-1-9
JohnLietzke
Flight distance : 3125968 ft
It is just a quest but I would have to second the battery coming loose.  It would explain also why the recording stopped.
2021-1-9
Lisa3 AKA Karen
The battery disconnect, loss of power, could explain why it fell from the sky.
But why did it change direction or did it not change direction?
2021-1-9
Donut
Lisa3 AKA Karen Posted at 1-9 14:23
He said on his first line that RTH was activated.
His first words were. “On return home.
Doug
2021-1-9
Stu.Baby
Flight distance : 52218 ft
I've just read this post about ice forming on the props causing the drone to fall out of the sky :
Can ice crash your drone? You bet it can…
It may not explain everything but it looked pretty cold in jcp_eu's video.
2021-1-9
Lisa3 AKA Karen
Ok but now posts 3 and 4 don’t make sense?
2021-1-9
Donut
Stu.Baby Posted at 1-9 15:40
I understand your thought.
But did the battery fall out when it hit the tree or did the before causing the crash.
I’d be going all around that tree with a metal Detector within 50 foot of the tree.
If battery is found then I’d say ice maybe and if no battery I’d say it fell out and caused it to loose power.
A CSI investigation, lol
2021-1-9
Lisa3 AKA Karen
He found the battery in post 4, took him a half hour to find, or was it the drone. No, that fell out of the tree and was caught.
Just so I understand, if you find the battery it could be ice, if you can’t find the battery it’s power loss.
Makes perfect sense.
2021-1-9
marc70
Flight distance : 4762470 ft
How do I follow this thread? By throwing in a reply? I want to know what comes out of this.
2021-1-10
djiuser_SUuARQ3kh5iK
Flight distance : 287224 ft
Just had the same problem, i lost trust in flying it high so i did a test flight, i set RTH height to 49ft, set a home position about 80ft in a middle of a field, stood by the mini2 and switched off the controller to simulate a lost signal, the mini just hovered facing the homepoint for about 10 seconds, then started going up to about 10ft, turned right, then shot off eratically like a rocket towards a main road, i paniced and switched the controller back on and managed to regain control before it hit anything, freaked me out, ive contacted DGI and waiting for responce, only had it 3 days and i dont want to risk flying it anywhere now just incase it looses a signal then goes flying into something.
2022-3-5
Mobilehomer
Flight distance : 18150351 ft
djiuser_SUuARQ3kh5iK Posted at 3-5 09:46
I read where you set Home Point to the middle of the field. Did you hover it at that spot and set home point? Did you hear or read Home Point updated. Please check the map.?
2022-3-5
colinwillo
Mobilehomer Posted at 3-5 10:57
Hello
I hovered then set the home point using the map, it said home point updated, you can see it in the flight log viewer where i set it, and it flew in the other direction, good job i was standing on the left of it, would have hit me in the head.
2022-3-5
colinwillo Posted at 3-5 13:35
Hello
Since you haven't included a link to the flight log viewer report, no-one can see anything of the incident.
Please post a link if you want any assistance.
RTH has proved to be quite reliable and the data is likely to show what's behind your incident.
2022-3-5
Mobilehomer
Labroides Posted at 3-5 14:52
That's why I asked about setting home point. I know most "flyaways" are due to a bogus or non- existant home point.
2022-3-5
fansec25ac0e
phantomhelp.com/logviewer/0JWCWC4YVUP2V2OPGRDG]flight log
think this will work?
it says i dont have permission to send links?
2022-3-5
fansec25ac0e
fansec25ac0e Posted at 3-5 15:12
or this
phantomhelp.com/LogViewer/LDKSI6TDGOEHGVD42L1W
2022-3-5
