Osmo Mobile 2
9983 12 2021-2-6
KArol Levy
Bonjour à tous,
Je me permets de vous poser une question concernant notre DJI Osmo 2
Nous avons un petit problème voici le message sur l'iphone 8 IOS 14.4 " Allumez le bluetooth du smartphone et revenez sur l'application " La dji Osmo fonctionne mais pas l'appli DJI GO ?
Merci pour votre aide .
Cordialement
K
2021-2-6
Hi, KArol Levy. Thanks for reaching out! Please turn on the Bluetooth of your iPhone and check whether the Osmo Mobile 2's Bluetooth is connected to your iPhone's Bluetooth. Once they're successfully paired, kindly open again the DJI GO.
2021-2-7
fansf5fe85da
Hi there, I’m having similar issues. My Bluetooth is turned on, the Osmo mobile 2 is on and it says it’s connected under my Bluetooth devices, however when I try to hit camera on the DJI Go app, it tells me I need to turn Bluetooth on...
I saw an earlier post about this on someone’s iPhone X running an older OS, and they just had to enable Bluetooth under the DJI app settings, however I’m using a XS on iOS 14.4 and there is no Bluetooth option under the app permissions anymore.
I’ve deleted and reinstalled the app too.
Any known solution for this?
Thanks in advance,
Mat
2021-2-11
igholter
Same problem here. Unable to connect my Osmo Mobile 2 to my iPhone 8. Turned bluetooth off/on, paired Osmo from Bluetooth list, opened DJI GO again. But when pressing "Connect Your Device", I get the same message over and over "Turn on the Bluetooth of your phone. Go back to DJI GO to reconnect".
Is this is a widespread issue with Osmo Mobile 2? Needs a fix!
2021-2-13
fans49f5ff4b
Same here too! I’m on iphone X 14.4
It seems that the app dji go 4 is not sensing that the Bluetooth is already turned on.
Anyfix?
2021-2-14
fans1aad91f9
Algeria
Hello
I have the same problem
Help please
2021-2-20
davecres
I have a similar problem Have connected my DJI Osmo 2 device to bluetooth. DJI Go app says osmo mobile 2 connected. I touch the camera button but the indicator to the right just keeps cycling. If I hit the record button on device it plays a ring tone.
Zoom button doesnt do anything. Im running the latest iOS 14 on iPhone 12 Pro Max
2021-2-21
Mivo
fansf5fe85da Posted at 2-11 09:48
Same issue. Most annoying!
2021-2-21
Mivo
Just deleted and uninstalled the DJI app, then ran setup and it fixed the issue. Good luck.
2021-2-21
Dieterdong
Same problem here. The Osmo mobile 2 has been working perfectly until my iPhone 8+ updated itself to ios 14.4. Very annoying as I am on a filming  job on a sailing boat  in a remote area and now can not use the gimbal anymore. Need a fix urgently!
2021-2-22
Dieterdong
Dieterdong Posted at 2-22 19:11
deleting the app, running set up and reinstalling the dji go app fixed the problem for me
2021-2-24
dickiek
Mivo Posted at 2-21 11:53
Sorry but it doesn't work for me. I have previously had my iphone x running fine, DJI pushed out app update, forced me to agree to new terms and it hasn't worked since, get the message re bluetooth. I have deleted and reinstalled app, tried the suggested fix for bluetooth and it doesn't work. I see many many people are having this issue and although DJI are quick to respond with the "turn off all" solution they then ignore the replies that plainly say it doesn't solve the issue. I have even seen DJI claim my model of iphone isn't compatible when it was before and others have also said it was. DJI seem to have deliberately bricked the osmo 2 in an attempt to force customers to upgrade - well it worked for me! I've just put an order in for a newer gimbal and it isn't from DJI!
2021-3-9
djiuser_ojGQZAkXfHDI
United Arab Emirates
davecres Posted at 2021-2-21 09:35
Dear Sir,
How to use Osmo Mobile 2 with 12 PRO MAX.
it’s not at all balancing.
Please help me.
2022-5-13
