Hi, fansa54db90e. Thanks for reaching out and posting your concern. Our apologies for the inconvenience that it has caused. Unfortunately, the iPhone SE isn't listed in our current compatible devices but if you have not tried, we suggest removing the RC Cable on both ends then wait for 10 seconds before reconnecting it and see whether that might work. You can also restart your iOS device while it is connected via RC Cable to the already powered remote then check if the connection can be established. Should the same problem persists, it is suggested to test it with another iOS device to further confirm whether this is a compatibility issue or there's a problem with your RC Cable. |
