Cannot update firmware on FPV and goggles
2891 4 2021-3-7
Jon-wales
Flight distance : 39692 ft
Just got the new DJI FPV, unpacked, charged the batteries full,
Downloaded DJI Assistant 2 FPV Series
plugged in controller and updated fine
Plugged in the goggles, and update fails at transmission stage
Plugges in the drone, and update fails at transmission stage
Attached is image of the error
Batteries are fully charged, tried several USB-C Cables
Also tried different Mac's as mine is the new M1, tried intel Macbook as well
Getting a bit annoying now as spent good amount of money on this, and cannot update it, dont want to fly until firmware updated
Please help!!!
2021-3-7
Craig S.
Flight distance : 150889 ft
Make sure that your equipment is fully charged before doing the update!
2021-3-8
Buzzyone
Flight distance : 4647913 ft
Make sure you are logged in too!
I updated using the fly app, which worked fine. When the motion controller arrived it wouldn’t update the firmware as the aircraft battery was too low, updated the motion controller using assistant 2 which it did! Went to fly and the system would not allow the
Motion controller to work as it reckoned the firmware wasn’t up to date rather annoying had to connect it via the fly app to complete the process. It seems the fly app is more reliable when updating etc.
2021-3-8
Jon-wales
Buzzyone Posted at 3-8 12:29
I gave up trying to update via DJI Assistant 2, just failed every time and all batteries are 100% charged
Ended up using the DJI Fly app and that has successfully updated everything
2021-3-8
Hello there Jon-wales. I am sorry for the trouble and thank you for reaching out. In addition to this I will post a DJI Tutorial video on How to Use DJI Fly App and Update the Firmware of the DJI FPV. Thank you.
2021-3-8
