Clint THPRD
I was having an issue getting IMU to calibrate. Plugged it into PC to check Assistant, but it wouldn’t see the M2P. When I unplugged it, the indicators started flashing through red, green, yellow like it was running self diagnostic, but it just kept on those colors. I left it like that for about 20 or 30 minutes before the battery started getting pretty low. Swapped batteries, gave the M2P a reboot, same colors on indicators. Was able to connect with the smart controller, and it was reporting IMU issues still, and it still wouldn’t calibrate. I tried connecting to pc again, but it still wouldn’t show up in Assistant. After another reboot or 2, it is now to the point where everyone else here is reporting. Power light comes on, fan comes on, propellers twitch slightly, gimble goes through a rotation sequence, and then nothing happens after. Smart controller sees the M2V for a sec, let’s you connect, but then bounces between weak signal, and disconnected. So… any ideas? This particular M2P is a little over 2 years old, and this is the first time, other then when it was initiated that we have to do any calibration. Before COVID it flew a few times a month, since COVID it flies about 1 or 2 times a quarter. |
