DJI FlyApp 1.4.0 Android Attitude Indicator Bug
1971 17 2021-4-17
fans04c304e5
Flight distance : 60375420 ft
Indonesia
My attitude indicator home point position going crazy when doing yaw movement.
2021-4-17
jonny007
Does it work for you with an earlier version? In my opinion, an update of the flyapp is superfluous anyway.
2021-4-18
fans04c304e5
Indonesia
jonny007 Posted at 4-18 02:08
Yes it should be like that, but not for this latest verison . Aready tried ver. 1.2.4 - 1.3.1 working fine for me. For now I only use version 1.1.0. I have been uninstall installed cleanly, delete all cache and DJI folder, reboot phone, still no good.
I will have to wait for everyone to test it, if this bug only affects on my phone or not.
2021-4-18
K6CCC
Flight distance : 651683 ft
That's interesting to watch.  That's one that if I could, I would go right outside and do a test flight, but it's WAY too windy for me to fly here today...
What phone are you using?
BTW, do you really have over 10,000 Kilometers of flight distance, or did yours get stretched out by the forum software?
2021-4-18
fans04c304e5
Indonesia
K6CCC Posted at 4-18 09:15
I'm using xiaomi redmi 9.
I dont know how this forum calculate flight distance. I only have 4758 km flight distance on my flyapp flight data center and always sync all my flight record.
2021-4-18
GaryDoug
Flight distance : 1264639 ft
How far away from the drone were you when that was recorded? If under 100 meters, that could explain it. The GPS is not as exact in your device, but normal. See if that happens when you are farther away.
2021-4-18
K6CCC
Problem confirmed.  The wind died down this afternoon and I was able to take my original Mini up for three short flights.
Flight #1 using Motorola G7 Power android phone with 1.4.0(937-official).  Problem observed almost exactly as the OP reported.
Flight #2 using Samsung Galaxy Tab A android tablet with 1.4.0(937-official).  Problem observed almost exactly as the OP reported.
Flight #3 using my @#$%^ iPhone 8 phone with 1.4.0(451).  The display operated correctly.
Aircraft firmware:  01.00.0500
Aircraft FlySafe database:  01.00.01.19
To answer Gary's thought, I did not go all that far away, and I would have to look at the data to give an exact number, but about 150 yards on each flight.  Mainly enough that the display clearly showed that there was distance from the aircraft.  I seem to recall that the iPhone (which decided to change me to metric), showed 152 meters.
2021-4-18
fans04c304e5
Indonesia
GaryDoug Posted at 4-18 18:23
I have tested more than 2km (6561ft) away to the sea, and became panicked after seeing the HP's position glitch it self out of the blue and bring back again for safer distance and test it again still same glitchy.
2021-4-19
fans04c304e5
Indonesia
K6CCC Posted at 4-18 19:36
Thanks K6CCC for the test.
I think this is a bug found on android version only.
Let's hope DJI fix this immediately.
2021-4-19
djiuser_1oS7PZ2UjB62
Flight distance : 640709 ft
Argentina
fans04c304e5 Posted at 4-18 02:56
Hola!!
Sabes desde donde puedo descargar la version 1.3 para DJI fly??
Se me actualizó a la 1.4, y he perdido la vista de cámara del drone, (Un Mini 1) pese a que la he desinstalado, reiniciado el celular ( Un galaxy S21, en el que funcionaba perfectgo la version anterior)) y vuelto a instalar y nada!!
No puedo volar.
Agradezco mucho cualquier aporte!!
Gracias de nuevo
2021-4-19
Flaming
Flight distance : 250541 ft
Well , at that point if your only drone is a Original Mini .. there is no reason to update beyond 1.10.   The original Mini is pretty dead to DJI and will never add new features
2021-4-20
fans04c304e5
Indonesia
Flaming Posted at 4-20 07:12
Yeah, old MM1 has been long forgotten by dji forever sadly.
I only use flyapp 1.1.0. BTW, I'm not hoping they add more feature to MM1, I'm just curious to test this version if there any significant UI changes or not. If nothing exciting, I just go back and forth installing the old one.
2021-4-20
Ph3onix
Flight distance : 2341886 ft
djiuser_1oS7PZ2UjB62 Posted at 4-19 15:42
Hola!!
hello here is the link for version 1.3.0 .
https://www.apkmirror.com/apk/dj ... -fly-1-3-0-release/
2021-4-21
ACHILEE5
Flight distance : 341493 ft
I have the same problem with my Mini 2 and Samsung S8 :\
2021-4-23
Ralle
Flight distance : 11289 ft
Finland
ACHILEE5 Lähetetty klo 4-23 08:43
Minulla on sama ongelma Mini 2: n ja Samsung S8: n kanssa: \
1.2.4 works well for me. I will not upgrade to version 1.4.0
2021-4-23
fans04c304e5
Indonesia
Yup 1.4.0 android full of bug.
Waiting for DJI to fix it during 2 or 3 week or maybe more for next update.
2021-4-23
crash1sttime
Flight distance : 1226368 ft
fans04c304e5 Posted at 4-23 14:30
Why not just downgrade to 1.3.0?
2021-4-24
fans04c304e5
Indonesia
crash1sttime Posted at 4-24 09:22
I'm currently using the older flyapp 1.1.0 (support only for mini 1 and Air 2).
Version that work best for me:
1.1.0 (currently)
1.1.9
1.1.10
1.2.4
Wait for dji to fix android version for latest version.
2021-4-24
