Connecting to Ipad
4063 15 2017-10-20
fans7ad6d23d
Flight distance : 13507 ft
Mali
Hi everyone, I just purchased an Ipad 9.7 128GB unit with Wifi & Cellular.
I have set this up as a brand new laptop, updated to the latest iOS and loaded the DJI GO App on it.
I connect it to my P4P controller, power on the controller, power on the drone, start the DJI GO app - and whilst the app starts it fails to realise that the bird is online. The "GO FLY" button never appears and if I force it into camera setting it shows as disconnected.
The IPAD pings when I connect the cable and there is a charging symbol so there is connectivity.
Does the iOS block access to the port and do I have to allow DJI access somehow ? Or have I missed a step ?
Thank you
Sean
2017-10-20
lannes
Flight distance : 4465 ft
The charging indicator is a bit of a worry, what OTG cable are you using, the fact it is charging does not suggest there is any data transfer
Try other OTG cables, if the one your using hasn't been used succesfully with your other AC
2017-10-20
DJI-Jamie
Flight distance : 112405 ft
Could you clarify which Go app version you're on? Have you ensured that both the unit and RC are up to date firmware wise?
2017-10-20
fans7ad6d23d
Mali
I have tried several different cables and also tested the cable with an iPad mini which works fine.
Not sure on the version of Dji but it is whatever is available on the App Store at the moment.
2017-10-20
DJI-Jamie
fans7ad6d23d Posted at 2017-10-20 20:24
Could you verify the firmware versions that are on the aircraft and RC? You can check them via the Assistant 2 Software as well.
2017-10-20
fans7ad6d23d
Mali
I have verified the firmware versions with Assistant 2 - and all up to date
2017-10-20
sky wombat
Flight distance : 1532215 ft
silly question but have you loaded  DJI GO Ap or  DJI GO4 Ap?
2017-10-21
DJI Elektra
Please provide the error message showed from your app. Your controller can control the camera of the AC, right?
2017-10-21
Antonio76
Flight distance : 144403 ft
lannes Posted at 2017-10-20 09:14
why should he use an *OTG* cable (which is needed in conjunction with an Apple Lightning cable to connect an iPad to the *aircraft* )  to connect an iPad to the P4P *RC* ? the standard Apple lightning cable that comes with the iPad is all he needs-even if a shorter one would be better.
2017-10-21
lannes
Antonio76 Posted at 2017-10-21 02:55
Yes you are right, I was trying to suggest the op try another lighting cable
like a Rock cable
http://www.rockphone.hk/en/produ ... egory=40&id=543
2017-10-21
fans7ad6d23d
Mali
lannes Posted at 2017-10-21 03:50
like a Rock cable
I have tried another cable.
I can confirm that I can control the aircraft from the controller.
I can confirm that I am using DJI GO APP 4.
I have read that this is a potential issue with iOS 11.0.3.
2017-10-25
Dockater
Flight distance : 139649 ft
RE: Connecting to Ipad
fans7ad6d23d Posted at 2017-10-25 05:08
Your comment - I have read that this is a potential issue with iOS 11.0.3.
I have, and use a p4p, with an iPad Pro and also an iPad mini with IOS 11.0.3 and I have no problems. Do not forget when installing new apps, software etc. that the hardware should all be rebooted ALSO THE iPAD.
2017-10-25
MiByrd
Flight distance : 17346 ft
I am having the same issue ... I just purchased the P4P and can connect with my iphone 8 no problem  - the controller , bird and iphone all synching  - in fact I was asked to upgrade the firmware when I first connected and did so successfully ... however, my Ipad 3 is a different story  - same as Fans7  - it will not connect and I am using the same wire as with the iphone  - I even deleted go4 app in my ipad and re-installed it and still no luck  - I cannot get it to connect my controller bird & ipad !
2019-2-7
MiByrd
I just updated my ipad ios to latest version 12.1.4 and that did the trick  ... I can now sync controller, bird and go 4 app inside ipad.  Possibly that will work for you as well fans7 ?  best of luck ...  Thanks.
2019-2-7
DeepFriedOprah
Flight distance : 1709094 ft
Mine has always shown that the iPad is charging when connected to the controller.
2019-2-11
jdcjet747400
Flight distance : 1781 ft
i cannot get my ipad to connect with dji p3s...any ideas?
2021-5-19
