GL300F controller charging issue
3385 14 2021-6-9
culnara69
Flight distance : 96014 ft
Hi there, wondering if someone can help me out
about a year ago I noticed a slight issue with my Phantom 4 Pro controller (GL300F) it wasn't charging fully...
as time has gone by it has gradually gotten worse to the point it will charge to 2 leds and flash on the third
when @fully charged@ it only shows one led, but left for a while, it goes to 2.5 (flashing)
I did contact DJI who quickly pointed out that the controller was out of warranty and that I would have to
send it back myself for repair, I did not follow through with this request.
This annoys me a bit as this seems to be a very common fault with this controller and I feel it should be repaired
free of charge...
anyway, the last flight I did was very frustrating because as the drone took off, the low battery beeping from the
RC started. not good for the nerves I can tell you.
Has anyone else had a similar issue and had to pay for a repair? if so, how much was it?
just trying to decide whether it is financially worth it
Regards
2021-6-9
LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi !
I think it's worth trying to replace it. Not sure it works! On Aliexpress there are some not too expensive.
Otherwise there is the procedure where it is necessary to solder resistors. As a last resort why not!
2021-6-9
culnara69
LV_Forestry Posted at 6-9 06:11
Hi !
Yeah, I did re-flow the solder joints and it fixed it for a while, but it's getting bad again
2021-6-9
LV_Forestry
Latvia
It only remains to exchange the battery !
2021-6-9
culnara69
LV_Forestry Posted at 6-9 06:41
I think the battery is fine, it may possibly be a faulty chip?
2021-6-9
LV_Forestry
Latvia
I don't know. You always have the option of sending it in for repair to get a quote.
I strongly invite you to contact online support. https://www.dji.com/en/support
Forum moderators are +/- useless but the online chat support is really nice and efficient.
2021-6-9
Hello there culnara69. I am sorry to read and to know that you are having this issue with your DJI Phantom 4 Pro remote controller ( GL300F ) and thank you for reaching out. I would suggest to send the said DJI remote controller in for assessment. Once our DJI support team had finished the assessment we will be sending you a notification of the analysis and on how much the cost. Just a friendly reminder that  DJI do not recommend doing a DIY in fixing the said DJI remote controller to avoid further damaging the said unit. Thank you.
https://www.dji.com/support
2021-6-9
culnara69
DJI Stephen Posted at 2021-6-9 19:49
I ended up buying another controller
2022-1-14
aairon
Flight distance : 72831 ft
culnara69 Posted at 1-14 13:22
Are you interested in selling your other controller?
2022-1-15
culnara69
aairon Posted at 1-15 19:43
I dunno? yeah the one that isn't charging correctly?
2022-1-16
aairon
culnara69 Posted at 1-16 02:21
yes that one, where are you located? I feel confident I can fix it easily.
2022-1-16
culnara69
aairon Posted at 1-16 04:01
I am up in Fraserburgh in Aberdeenshire, I did re-flow the solder on the motherboard and got it working perfectly but within a couple of months it slowly slipped back to worse than it was before
2022-1-16
aairon
culnara69 Posted at 1-16 13:54
I'm near Seattle, WA The symptoms you have described point directly to a battery cell deteriorating. As a matter of fact I'm confused that the seemed to have gone first to the least likely suspects. Replace the cell and have yourself a back up. P.S. the cell through amazon or the like should be super cheap less then $30 usd. good luck.
2022-1-17
Hi there culnara69. Thank you for the reply and for giving out these information and update. If you have any inquiries or any concerns with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Thank you and have a nice day.
2022-1-17
culnara69
aairon Posted at 1-17 21:19
Yeah a bit too far for sending economically, the reason I went for the solder re-flow first is because that was what all the google search results were pointing to when searching for (P4P RC not charging)
doing so did fix the RC 100% and it would fully charge and work normally, for the first couple of months anyway, then it slowly slipped back to fail, I did check the battery with a volt meter and it was basically fully charged, I ended up getting another one off of Ebay for £130
I did not find anything pointing to a faulty RC battery when googling that's why I went for the solder re-flow.
2022-1-18
