HGDC84
![](https://forum44.djicdn.com/data/attachment/common/4e/common_26_usergroup_icon.png) Captain
Finland
FP63 Posted at 8-7 00:43
I’m definitely not a genius when it comes to programming but maybe I have an idea for DJI technicians. Before putting the pocket 2 into the underwater casing, you need to go into the accessory menu and switch on the underwater mode. They just have to link this action to the way the mode button works on the underwater casing . Let me explain.: At this moment you press once to power the unit on the mode button on the casing . If you press more then 2 seconds, you are locking the display witch is completely unusable in the casing ! They just have to change that action in the underwater mode that will power off the unit pressing more then two seconds on the mode button instead of locking the display. What do you thinking about that DJI?
Something like that or pressing the mode button a certain amount of times could do the trick, and I also believe it wouldn't be that hard to implement in an update. But the engineers probably know it best... Hopefully this would be possible. |
