error del servidor(-2)
6258 47 2020-1-25
alemdelbariro
hola muy buenas!Acabo de comprar un mavic air y al intentar activar la garantia me sale este errror....que puedo hacer?
2020-1-25
Hello and good day alemdelbariro. I am sorry for the trouble this has caused and thank you for reaching out. Are you able to send me the serial number of your DJI Mavic Air through PM for me to be able to check and assist you further. Thank you.
2020-1-25
alemdelbariro
DJI Stephen Posted at 1-25 15:04
2020-1-25
Hello and good day alemdelbariro. Thank you for providing me the serial number of your DJI Mavic Air through PM and I have sent you a PM as well. Kindly please check your PM if you have time. Thank you.
2020-1-26
alemdelbariro
DJI Stephen Posted at 1-26 10:47
ya lo he leido gracias,ahora tengo que esperar? llevo una semana y media con el drone y no puedo utilizarlo
2020-1-28
Flight distance : 125755 ft
Panama
Hola, mi drone tiene el mismo error del servidor  y no puedo volarlo, necesito ayuda
2021-8-2
DJI Natalia
@chicho1986 Posted at 8-2 18:42
Hi there, may I know the model of your drone? Could you please show me a screenshot of the error message prompt in your app? I'd like to help you check it. Thanks.
2021-8-3
djiuser_o2KGJjosXndE
Buenos dias tengo el mismo problema, como lo puedo solucionar. Gracias.
2021-11-28
DJI Wanda
djiuser_o2KGJjosXndE Posted at 11-28 05:56
Hello, there. Sorry for your inconvenience. Would you please tell us your SN and screenshot the error message for us? You may send us SN through PM. Thanks!
2021-11-28
Alexdky33
Flight distance : 3079656 ft
Mexico
Hola quien tiene la solución de para activar mavic air (Error de Servidor(-2) no lo que podido volar en mucho tiempo
2022-6-15
DJI Natalia
Alexdky33 Posted at 6-15 11:23
2022-6-15
fanseda07122
Flight distance : 86870 ft
Paraguay
Hola tengo el mismo problema con un mavic air Error - 2
2022-6-22
fanseda07122 Posted at 6-22 16:31
Hi there, I am sorry for the issue. Could you please provide the serial number of your aircraft for further checking? Look forward to your reply.
2022-6-22
fanseda07122
Paraguay
Hi dji susan mi serial is 0K1DF312AD4W7T
2022-7-8
fanseda07122 Posted at 7-8 11:39
Hi there, thank you for getting back to me. As per the serial number, the drone had been activated on 8 July 2018. May I know if you purchased it brand new or did the drone experience any repair previously?
2022-7-8
fanseda07122
Paraguay
hi Susan The drone had a repair, change of main board, and when turning it on for the first time it gave the activation message. I was able to fly using the litchi app, but with dji go it asks for activation
2022-8-6
fanseda07122 Posted at 8-6 11:47
May I ask where you have sent the drone for repair? In this case, you may need to contact DJI Support through the link below and send it back for further diagnosis. http://www.dji.com/support
2022-8-7
fanseda07122
Paraguay
I changed the main board, it works perfectly with litchi
2022-8-7
DJI Natalia
fanseda07122 Posted at 8-7 18:42
Thanks for the update.
And if you need any support, you can contact us here anytime.
2022-8-7
djiuser_o5Vxr6YhKWOh
Hello i have to change by myselft a gimbal to a mavi air 1, with an old dji go 4 version i have no issues, but it ask me for activation with last version of the app, could you please assist me? the gimbal is from another mavic air i own also
DRON serial number is 0K1CG9NRAJ13SW  ERROR IS:
Error de activación. el dispositivo no es el que se esta activando, conectate a a un dispositivo DJI original
many thanks
Regards
2023-2-7
djiuser_o5Vxr6YhKWOh Posted at 2-7 05:53
Hi there, we do not recommend that you repair the drone on your own, which may cause safety issues. In this case, you may need to submit a case through the link below and send it back for further assistance. http://www.dji.com/support
2023-2-7
DJI Mindy Posted at 2-7 23:41
Sorry Mindy the dron is a bit old now , i promess i will do with brand new ones ... the question is why you guys block the dron from the application when it is totally funtional?
Thanks in advance
2023-2-8
djiuser_o5Vxr6YhKWOh Posted at 2-8 00:32
Thanks in advance
May I confirm if you mean the drone cannot connect to the DJI Go 4 before you replace the gimbal? Hope you understand that it depends on many factors. But due to the drone does not work normally now, we recommend that you send it back for further diagnosis and repair. If the issue still exists, you can contact us and we will help you then.
2023-2-8
DJI Mindy Posted at 2-8 02:03
Yes, it connects and i see the video signal of the dron but suddenly it ask me for activation, then when i go through all steps and finally i enter my dji accound details it shows the mentioned error.
If i run and old dji version for android i can used the dron with no errors, the error appears with latest IOS version
Thank you
Regards
2023-2-8
djiuser_o5Vxr6YhKWOh Posted at 2-8 06:11
As we explained above, it's not recommended you replaced the drone on your own. We recommend that you send it back for diagnosis and repair first. If the issue still exists after the repair, you can contact us then and we will help you further.
2023-2-8
djiuser_5RfCCZRh5262
Hola, muy buenas
Yo acabo de comprar un dji mini 3 pro, aún ni lo he encendido, cuando voy a activar la cuenta con el DJI RC me sale el error de servidor(-2)
2023-5-13
DJI Wanda
djiuser_5RfCCZRh5262 Posted at 5-13 22:59
Hola, muy buenas
Hello, there. We apologize for the inconvenience. If the error code appears when you try to activate the device, we will recommend you send it back for further diagnosis.
Here is the link: https://www.dji.com/support/repair?from=store_homepage
2023-5-13
djiuser_qo1JreWkQb2p
Flight distance : 310131 ft
Colombia
I also have the same problem. How can i solve it... i cant use my new drone
2023-8-10
djiuser_qo1JreWkQb2p Posted at 8-10 10:55
Hi there, thank you for reaching out. Would you please provide us the device serial number for further checking? If it is inconvenient to post here, you could send me a PM. Thanks.
2023-8-10
djiuser_LRhwD9KtsTzO
Mexico
No puedo activar mi dron me sale un error de activación, lo compre usado y la persona que me lo vendió lo tenía jalando sin problema, pero al configurarlo con mi móvil aparece ese error, de que no es un equipo original
2023-9-3
djiuser_LRhwD9KtsTzO Posted at 9-3 13:42
Hi there, thank you for reaching out. For your concern, please provide us the device serial number for further confirmation, thanks.
2023-9-3
Ana María Ortega
Flight distance : 4514 ft
Chile
Mi dron presenta el mismo error. Favor su ayuda porque no lo puedo volar.
Dron mini 3 pro
Número de serie 1581F4XFC231U007URXX
2023-10-6
DJI Wanda
Ana María Ortega Posted at 10-6 15:28
Dron mini 3 pro
Hello, there. Sorry for the inconvenience. Which remote controller you are using?
Can we have the SN of the remote controller as well?
Thank you.
2023-10-6
Luis Lechuga
Mexico
Tengo este problema con el Mavic air 2, si puede volar con el sistema Android pero no emprende vuelo con el sistema IOS y pide activación pero me aparece el error (0xffd), porque este error me marca solo con el sistema IOS y como puedo resolverlo? Saludos y gracias
2023-11-13
Luis Lechuga Posted at 11-13 14:59
Tengo este problema con el Mavic air 2, si puede volar con el sistema Android pero no emprende vuelo con el sistema IOS y pide activación pero me aparece el error (0xffd), porque este error me marca solo con el sistema IOS y como puedo resolverlo? Saludos y gracias[view_image]
Hi Luis, thank you for reaching out. May I know if the aircraft has been repaired at an officially authorized repair center recently?
2023-11-13
Luis Lechuga
Mexico
DJI Thor Posted at 11-13 19:06
Si asi es, ¿que podria ser o como podria solucionarlo?
2023-11-14
Luis Lechuga Posted at 11-14 08:58
If yes, would you please provide us the case number and your device serial number? We will forward to our engineer team to further check. Thanks.
2023-11-14
Joan Didac Contreras Gutierrez
Hola, he Colorado un DJI Miki 4 Pro y quiero desbloquear el límite de 120 m y pasarlo a 500 m. He actualizado el firmware y me sale este mensaje
Error de servidor. Espera un momento y prueba de nuevo.(Code:0x1151009fffff)|
Que debo de hacer ya que no puedo actualizarlo
Mi emai es jdidac@collbaix.com
2023-12-3
Joan Didac Contreras Gutierrez Posted at 12-3 06:36
Hi there, please follow the below steps to troubleshoor first. Thanks.
1. Please check if the RC system date&time zone is consistent with the local time. If not, please set as the same to retry.
2. It is recommended to check your current network status. You could use another network(Wi-Fi or Hotspot) and log in with your DJI accounts again to try.
3. Please try to use the DJI Assistant 2 to upgrade the firmware.
2023-12-3
MARCUS DUARTE
Flight distance : 1965541 ft
DJI Stephen Posted at 2020-1-25 15:04
Hello, Goodnight.  I bought the Mavic Air 2, but when I tried to use it with the iPhone I couldn't. Requires device activation. Trying to activate presents the error as in the attached photos. I would like help to resolve this problem. I send the drone data. But with Android it worked normally
3-16 17:16
