the orbit is not working
653 6 2021-8-9
djiuser_MPgpE5PvMYli
Орбита не работает! Как я могу это исправить? Калибровка подвески не помогла.   The wind is very weak. There are no birds flying.  .
2021-8-9
Mini2 Flyr
Flight distance : 4347785 ft
Hi djiuser_MPgpE5PvMYli. Thank you for these wonderful video you have made and shared. Looking forward to see more of your video postings in the future. Have a happy and safe flights always.
2021-8-9
Tez4UK
Flight distance : 142349 ft
not sure if it makes a difference but could you be to close to the subject your trying to orbit round ?
2021-8-9
jonny007
? A new DJI bot undercover ? On the subject....probably the target isn't selected well, but I think the object itself isn't suitable for staying in focus due to the shape of the object and the contrast to the surroundings. Try another object.
2021-8-9
jonny007 Добавлено 8-9 05:11
? Новый бот DJI под прикрытием? По теме ... возможно, цель выбрана неправильно, но я думаю, что сам объект не подходит для того, чтобы оставаться в фокусе из-за формы объекта и контраста с окружающей средой. Попробуйте другой объект.
Вот еще один взгляд! Что вы на это скажете?
2021-8-9
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try flying your DJI Mini 2 to a different location and take some Quickshots to see if the issue will still persist? Just a reminder to use Quickshots at locations that are clear of buildings and other obstacles. Make sure that there are no humans, animals, or other obstacles in the flight path. Please pay attention to objects around the aircraft and use the remote controller to avoid accidents with the aircraft. DO NOT use QuickShots in places that are close to buildings or where the GPS signal is weak, otherwise, the flight path may be unstable. Make sure to follow local privacy laws and regulation using QuickShots. DO NOT use QuickShots in any of the following situations:
a. When the subject is blocked for an extended period or outside the line of sight.
b. When the subject is more than 50 m away from the aircraft.
c. When the subject is similar in color or pattern with the surroundings.
d. When the subject is in the air.
e. When the subject moves fast.
f. The lighting is extremely low (< 300 lux) or high (> 10,000 lux).
Thank you.
2021-8-9
Sokolru
DJI Stephen Добавлено 8-9 20:06
Привет. Мне очень жаль, что это вызвало неприятности, и спасибо, что обратились к нам. Не могли бы вы попробовать перелететь DJI Mini 2 в другое место и сделать несколько быстрых снимков, чтобы увидеть, сохраняется ли проблема? Напоминаем, что можно использовать быстрые снимки в местах, где нет зданий и других препятствий. Убедитесь, что на траектории полета нет людей, животных или других препятствий. Обратите внимание на предметы вокруг самолета и используйте пульт дистанционного управления, чтобы избежать несчастных случаев с самолетом. ЗАПРЕЩАЕТСЯ использовать QuickShots в местах, близких к зданиям или где сигнал GPS слабый, в противном случае траектория полета может быть нестабильной. Обязательно соблюдайте местные законы и правила о конфиденциальности при использовании QuickShots. НЕ используйте QuickShots в следующих ситуациях:
а. Когда объект заблокирован на длительное время или находится вне прямой видимости.
б. Когда объект находится на расстоянии более 50 м от самолета.
Места разные - результат отрицательный.
2021-8-9
