Max Battery Temp
5214 31 2021-8-16
tony.simek
Flight distance : 11229610 ft
Hello - For any Mini-2 flyers that have looked at the battery log, hoping you could educate me on what the max temperature is that you have seen.  Just getting some data for my own edification because I do not know what is a normal range during use.
2021-8-16
Just checked my logs back to a warm day earlier in the year and I get this -
Min Temperature 24.90c
Max Temperature  36.30c
2021-8-16
TonyPHX
DAFlys Posted at 8-16 23:34
Thank you!  I appreciate the input.  Some interesting background on why I am asking, I took a short ~12 minute flight the other day with one of my Mini-2's and upon packing up to walk back home, I found that the battery had expanded in-flight to the point it could not be removed.  And I mean it was really in there.  : ) For safety sake I did not want to get to aggressive, but let's just say I worked at it for a bit.  Since it was a fairly new drone and the battery had only been charged five times, DJI support was very good and had me send back to them.
I pulled the logs off the smart controller, and saw that my battery temp had spiked at the end of the flight to 63c.  Admittedly I live in Arizona, and it was a hot day, but I have flown many times on days equally hot and never had thermal issues like that.
Given the variance between your highest reported and mine, I am willing to bet on a defective battery being the cause for my issue.  Thank you again!!
2021-8-17
TonyPHX Posted at 8-17 00:20
What was your start temperature.   Mini2 is only rated to start at below 40c (104f).
2021-8-17
Mini2 Flyr
Flight distance : 4347785 ft
Hi tony.simek. I fly my drone in Australia and my Mini 2 battery has on occasion reached a high of 59 degrees celsius. Quite hot but this caused no issues to my drone at all.
2021-8-17
Alvara74
Flight distance : 30364 ft
Mini2 Flyr Posted at 8-17 00:51
Doesn't your battery swell?
2021-8-17
Alvara74
DAFlys Posted at 8-17 00:27
So does that mean that the battery can start at below 40c but is capable of operating above that temp?
2021-8-17
Alvara74 Posted at 8-17 02:26
Operating range of the mini itself is 0° to 40°C,  so if its 41c its too hot to take off.
2021-8-17
marc70
Flight distance : 6043002 ft
So if I want to fly on a hot day, would it be ok to store my batteries in a cooler? Then load them in my Mini2?
2021-8-17
djiuser_nO2RdSW5BSUg
Flight distance : 80646017 ft
I happen to reach the battery temperature even 65 degrees. The air temperature does not exceed 25 degrees. I just do a long flight against a strong wind in sport mode. The battery hasn't broken down yet, but the temperatures are not good for it. The main thing is not to charge a hot battery.
2021-8-17
Johnny_J
djiuser_nO2RdSW5BSUg Posted at 8-17 06:47
Also when you fly horizontally (not hover) the air intakes will cool the inside of the drone.
2021-8-17
Johnny_J
marc70 Posted at 8-17 05:46
Lithium-ion batteries do not appreciate cold or hot temperatures.
Read more here:
https://enterprise-insights.dji.com/blog/dji-drone-battery-tips
2021-8-17
TonyPHX
Well below I believe, but I will go back and look!  Thank you for the info!  I did not know about the startup enforcement but that makes good sense to protect the drone and battery!
2021-8-17
TonyPHX
Johnny_J Posted at 8-17 07:04
Read more here:
Good article, thank you!!
2021-8-17
TonyPHX Posted at 8-17 11:30
Have a look at  airdata.com you can sync your last 100 flight logs for free and get some insight into temps etc.
Ps Jonny_j appears to be a troll based on the other posts and doesn't have a DJI drone based on his avatar.
2021-8-17
djiuser_VWpYJLm4Lky3
Flight distance : 37451 ft
Hello everyone, I always have a question about the battery, when it is charging and all 4 LEDs are on, do I have to wait for them to go out before disconnecting the cable? Thanks for the reply
2021-8-17
TonyPHX
My starting temp was 27c.  It really heated up near the last 30 seconds of flight, so I think that's when it fried itself.  Thanks again for the data, you helped me understand what I am seeing.
2021-8-17
TonyPHX
DAFlys Posted at 8-17 11:58
I also purchased a flight reader license for Windows.  I like having the capability without the upload.
2021-8-17
TonyPHX
Agreed.  I always let them sit and acclimatize to indoor temps before putting back on the charging stations.  Good reminder.  My Ryobi power tools batteries will even prevent charging when they come inside hot.
2021-8-17
Hello there tony.simek. I am sorry for the trouble this has caused and thank you for reaching out. Just a reminder that the DJI Mini 2's Operating Temperature is from 0° to 40°C ( 32° to 104°F ). In addition, it is good to know that you have already contacted our DJI support team for assistance with regards to this matter. Thank you
2021-8-17
Flight distance : 2354357 ft
djiuser_VWpYJLm4Lky3 Posted at 8-17 12:44
Not if they are solid...
2021-8-17
TonyPHX
DJI Stephen Posted at 8-17 19:15
Yes, thank you.  I think that when I went flying it was in the upper 90's so I felt pretty good.  Comparing other log files, the battery always reached a peak and never got hotter.  This one was a rare exception.  But yes, DJI care took good care of me!  Thank you!
2021-8-17
TonyPHX Posted at 8-17 20:07
Hi there TonyPHX. You are very much welcome and thank you for these additional information that you have given. If you have any other concerns or any inquiries with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Have a safe and a happy flying always. .
2021-8-18
Alvara74
DAFlys Posted at 8-17 03:37
Ah okay, thanks! Also, by these temperatures, do you mean the temperature of the area or the battery temperature?
2021-8-20
Alvara74 Posted at 8-20 09:13
Its ambient temperature.
2021-8-21
Alvara74
DAFlys Posted at 8-21 00:37
whats that?
2021-8-24
Mobilehomer
Flight distance : 18150351 ft
Google is your friend
2021-8-24
red_canyon16
Flight distance : 24446450 ft
The hottest mine has gotten was 146.7F which is around 63C I think.
2021-8-24
TonyPHX
red_canyon16 Posted at 8-24 14:32
Cool.  Thank you @red_canyon16 for the update.  My 63C was pretty fatal to that battery.  Sounds like you fared better than I did.  : ).
DJI got me fixed up so I'm all good now.
2021-8-24
https://lmgtfy.app/?q=ambient+temperature&iie=1
2021-8-24
Hannibal_
Flight distance : 297126 ft
I am a drone novice, but yesterday the mini 2 also got pretty warm, even before takeoff
I would like to check the temperatures. Where can I find those logs?
2021-8-25
TonyPHX
Hannibal_ Posted at 8-25 00:27
I connected a USB cable to my smart controller and pulled them off from there.  I then read the data in a app I found online.  Flightreader or something like that.
2021-8-25
