Flight distance : 2354357 ft
Towards the end of the quickshot is where it lost is, RTH kicked in on its own, there must be sommat around those houses giving off some crazy interference, fly there again and see if it does it again, in future, trust auto RTH will do this, don't press the remotes RTH cause you could inadvertently cancel the RTH, been done before. Also, use the attitude indicator in the bottom left to know where you're pointing the controller in reference to where the AC is, granted, you're only about 300m but with those houses and you only at about 50m in height, and CE mode, that mix is probably what caused the signal loss. |
