Hi guys my dji drone disables manual mode when i fly over 100 meters
685 7 2021-9-26
Nicofly
Hi guys my dji drone deactivates manual mode when i fly over 100 meters does anyone know how to deactivate this i live in switzerland if this is necessary thanks for the help
2021-9-26
TimboSlice
Flight distance : 2935351 ft
I had the same issue, but it only happens when i fly in 'restricted' zones it seems like.
Although i'm not completely sure if that is the exact reason.
2021-9-26
Hello there Nicofly. Thank you for reaching out and for these information that you have given. Kindly please try checking the location from this DJI link ( https://www.dji.com/flysafe/geo-map ) where you fly your DJI drone to see if there are restrictions on the location. Thank you.
2021-9-26
Nicofly
Yes im flying in a restrected Zone nur the maximum high is 150 meters in the Sport and normal i Chan Fly 150 and With the Manuel Mode i can fly Not Ober 100 Meters what is the Problem?
2021-9-26
Whoreable
Flight distance : 1775299 ft
get the drone hacks installed now unlimited
2021-9-27
TimboSlice
Whoreable Posted at 9-27 01:04
I have seen this mentioned quite a few times now, do you have a source by any chance?
2021-9-27
KerryG
Flight distance : 11736709 ft
There is about a 40 meter "buffer zone" below your max flight altitude. If you go into that buffer zone, manual mode will turn off.
2021-9-27
frankymusik
Flight distance : 27904331 ft
Yes, just stay under this 100m .....
2021-9-27
