High-temperature mode
6012 42 2021-11-1
tacchan23
I know this setting isn't available in Europe/UK.
But exactly how is this achieved? If I buy the camera in Europe but then I later use it in a different continent, will the setting be available there?
Does it depend on the current location or the activation region or?
2021-11-1
Gramps50
Flight distance : 57841 ft
Can't say for sure but my guess would be the country where it was registered. Think that would be a DJI question
2021-11-1
JodyB
Flight distance : 302536 ft
That is a good question. This is the first DJI camera that I know of this has came up for I know the drones go by where you are when you’re taking your flight but I’m not too sure about just a camera.
2021-11-1
dcrainmaker
Flight distance : 477310 ft
It's based on the location of your phone, when the unit connects to your phone.
As a real-world example, yesterday I was in Florida. I had the 'high' setting toggled. Last night I flew back to Europe. Just now I powered on the Action 2, and the high setting was still available just fine.
However, the moment I opened up the DJI Mimo app and it connected to the camera, the DJI Mimo app informed me it needed to do a configuration update on the Action 2, and then restart it (virtually identical to what it does for drones when changing countries, if you're familiar with that). Upon the restart, the 'High' option was greyed out, and I was forced back to standard.
2021-11-2
fansfe82067d
dcrainmaker Posted at 11-2 13:12
Great info.  Personally I haven't used the high setting yet (here in Australia) because I've not needed to, and when provoked to overheat by non-typical use indoors, it does get so hot even at that setting that instinct tells me not to allow it to get even hotter, for its own good and also to preserve the skin on my fingers!
2021-11-2
tacchan23
Thanks a lot!
So I guess I will buy it in Europe before travelling
2021-11-2
tacchan23
Thanks a lot!
So I guess I will buy it in Europe before traveling
2021-11-2
tacchan23
Thanks a lot!
2021-11-2
fansb421f517
Could somebody please confirm this? It could have been a coincidence.
When I bought the camera, I could use the high temperature mode in the EU for a few days, before it got disabled by the Mimo App.
I'm trying to get it unlocked with simulated GPS positions an VPN connections to locations outside the EU, but no luck so far.
2021-11-15
djiuser_OhfvPirUX3cl
Austria
fansb421f517 Posted at 11-15 03:03
id also like to know iof anyone got it working properly in eu
2021-11-22
JBhatti
dcrainmaker Posted at 2021-11-2 13:12
Thanks for the tip. (And for making so many useful videos!)
When I first got the camera, in the UK, the high temp setting was available. It got greyed out a few days later. In theory then, "someone" could turn on a VPN set to USA on their smartphone, then connect to their camera via Mimo, which will re-set the camera and allow the camera to use high-temp setting again. And it will stay that way until you re-connect to Mimo again.
That's useful to know.
2022-1-12
djiuser_DukswYHuMhli
I just bought the action 2 and I’m based in the uk. Even at 4k30 it overheated after 5 mins. I tried using a vpn to USA but the camera doesn’t let me select the higher temp mode. Anyone had any luck? On the location services setting on my iPhone the DJI link app isn’t using my phone’s location so not sure how it is working out where it is.
I’ve got the magnetic case on order so I’ll see if that improves it.
2023-9-4
lutzmix
djiuser_DukswYHuMhli Posted at 9-4 12:42
use the camforpro hack, you can choose normal/high temp
2023-10-14
lutzmix
4k 60fps screen off only camera modul
17:50
2023-10-14
lutzmix
lutzmix Posted at 10-14 12:41
4k 60fps screen out only camera modul
17:50
4k / 30fps  codec 265 recording time 75 min on SD card Samsung EvoPlus 128GB Dual Screen off
neg: small internal memory no OTG.  pos: Price/performance dual screen combo for €250€
2023-10-14
lutzmix
lutzmix Posted at 10-14 17:50
Camera modules 1080/30fps 43 min (17gb), the Insta go 3 isn't better either!
2023-10-14
lutzmix
Solo Camera module HEVC 1080/60fps 36min, memory full, battery empty 50min
2023-10-15
lutzmix
4k/120 fps. 11:30 min,
same time with OA3
2023-10-20
lutzmix
Do not use the lower magnetic protective case during extreme sports. The clip only sits in the case and the entire camera can slip out!
This is a design flaw!!!
upper cage, you cant use filter
2023-10-24
lutzmix
4k/120fps 16:9. 18'20''
camera with Ulanzi Alucage and added accu modul
file intern storage
2023-11-10
lutzmix
4k/120fps rs. storage on sd
start temperatur 21⁰ C
screen off   48min accus empty
Dualscreen combo with Ulanzi cage!
2023-11-13
Maxime Bermond
lutzmix Posted at 11-13 11:24
This cage?
2023-11-13
lutzmix
Maxime Bermond Posted at 11-13 12:00
This cage?
yes this cage
the buttons are easy lost, you can fix it with glue
2023-11-13
Maxime Bermond
lutzmix Posted at 11-13 12:03
yes this cage
So the Ulanzi cage does much better than the official magnetic cover. OK for the buttons, what kind of glue? Thanks!
2023-11-13
lutzmix
Maxime Bermond Posted at 11-13 12:26
superglue or similar,
I think with the accu modul you get some minutes more
2023-11-13
lutzmix
So the Ulanzi cage does much better than the official magnetic cover. !
Plastic is a poorer heat conductor than aluminum, and the surface area of ​​the aluminum cage is larger
The greater the difference between ambient temperature and camera, the better the heat dissipation works
This works worse in midsummer
2023-11-13
lutzmix
attencion:
I must test it again
with accu modul only  28 min ??¿ camera shut down
2023-11-13
lutzmix
iff you stay in EU dont use the Mimo App it will change the temperatur status!!
2023-11-14
Maxime Bermond
lutzmix Posted at 11-13 20:55
What is accu modul?
2023-11-14
Maxime Bermond
lutzmix Posted at 11-14 01:41
The first time you have to use Mimo for Action 2 activation and then, in EU countries, it eliminates your ability to set the temperature threshold to HIGH. How do you go back?
2023-11-14
lutzmix
copy the crackconfig file to the sd card
start the camera and wait to shut down by empty accu. than insert the sd card
realistic operation time 4k/120fps. 25⁰C no moving
dji cage plastic 11-13 min
sd card : Samsung EVO plus
Ulanzi cage  aluminium 20min
2023-11-14
Maxime Bermond
lutzmix Posted at 11-14 13:20
https://youtu.be/2P0ubXCI5Hc?si=yaK5KL_NOMoDiFow
Does crackconfig file also work with Action 2? I thought it was good from Action 3 onwards. OK, I'll try to get both camera batteries discharged without the sd card
2023-11-14
lutzmix
I use the crachconfig file!
you need it for 4k/120fps 16:9
and
4K/60fps 4:3
crackconfig  works also with osmo pocket 3 (own risk)
you need the mimo app only for update files
2023-11-14
lutzmix
with theOrbmat cage you have minimum 5 min more opration time
25min and up  4k/120fps
2023-11-14
lutzmix
lutzmix Posted at 10-24 22:57
[Image]
DJI protective cover: the holes for the lanyard are on the opposite side, that's nonsense
2023-12-21
lutzmix
DJI protective cover: the holes for the lanyard are on the opposite side, that's nonsense                            original DJI product
The holes on this side are pointless!
2023-12-21
snatch
lutzmix Posted at 11-14 20:24
https://youtu.be/VaZ2l7rWeps?feature=shared
How did you get the crack to work (action 2)?
I put the file in the root of the SD card, but when I go to the high temperature settings it is disabled
2023-12-23
lutzmix
turn camera on and waIt to discharged camera shut down.enter the sd card and start again.
on my sd card is the zip file slso unzip
in EU/GB dont use mimo app it will changed the high. temp modus to disable
2023-12-23
djiuser_c2IR4N2vfEQg
You can enable high Tempurature mode by using an app called "Fake GPS Location" which is a free app in the Google Play Store.  I've not found a similar app in the Apple App Store so this only works on Android phones.  All you need to do is start the Fake GPS app, set a locaton outside of the UK/EU, I set a location in New York.  Start the DJI Mimo app and connect to your Action 2 Camera.  This will fool your camera that it's outside the UK/EU and you should then be able to enable the High Temp setting, then disconnect from the DJI Mimi app.  This setting will remain in the camera and can switch modes back and forth as long as you don't go into the DJI Mimo App using a UK/EU location.  If you do, you can use the Fake GPS app again to re-enable it again.
1-8 13:12
snatch
lutzmix Posted at 2023-12-23 02:37
Not working on Action 2..
1-8 23:51
