NAZA S2 SWITCH
1625 20 2015-1-3
swmarwood
S2 switch only has 2 positions? NAZA requires 3rd position for return home....
2015-1-3
rod
Hi, in NAZA mode you can set S1 for return home,  S2  only has 2 active settings and of course off in the upper position. (off,CL and HL.)
Rod
2015-1-3
Gerry1124
S1 switch set to Failsafe, RTH
2015-1-3
mark_turner6920
Flight distance : 1129 ft
Mine has a 3 position switch, top middle and bottom. What version have you got? A bit more info might help.
2015-1-3
Gerry1124
mark_turner6920 Posted at 2015-1-4 05:29
Mine has a 3 position switch, top middle and bottom. What version have you got? A bit more info migh ...
Top position is off, center position is CL and bottom position is HL on the s2 switch
top position on s1 is GPS
center position is ATTI
bottom position is failsafe or RTH
2015-1-3
MacCool
S2 switch has three positions. When activated in NAZA-M mode, they are typically IOC Off - Course Lock - Home Lock
2015-1-3
swmarwood
MacCool Posted at 2015-1-4 05:35
S2 switch has three positions. When activated in NAZA-M mode, they are typically IOC Off - Course Lo ...
My R/C is brand new & S2 only has 2 positions?
2015-1-3
rod
swmarwood@shaw. Posted at 2015-1-4 05:41
Really?  no top middle and down?  that is new! is this the controller with the wheel to the left?
2015-1-3
swmarwood
rod@voxvideopro Posted at 2015-1-4 05:50
That is correct, so don't know if I can set home function?
2015-1-3
Gerry1124
here is the position of the switches.
2015-1-3
MacCool
Sounds like a defective switch then.
When you run it through the calibration sequence in Phantom2 Assistant, what does does it show?
2015-1-3
Gerry1124
When you have the switch all the way to the top and move it 1 click to the center, then 1 more click to the bottom, you have 3 positions.
2015-1-3
swmarwood
MacCool Posted at 2015-1-4 05:55
When you run it through the calibration sequence in Phantom2 ...
It will not switch to third position, so does not show in calibration.
2015-1-3
Gerry1124
swmarwood@shaw. Posted at 2015-1-4 05:58
So, you're only feeling and hearing just 1 click?
2015-1-3
swmarwood
Gerry1124 Posted at 2015-1-4 06:00
Absolutely! Any new r/c controls out there to confirm only 2 positions on S2?
2015-1-3
MacCool
swmarwood@shaw. Posted at 2015-1-4 06:03
It's a defective switch. All new DJI transmitters have both switched S1 and S2 as three-position switches.
2015-1-3
swmarwood
MacCool Posted at 2015-1-4 06:06
It's a defective switch. All new DJI transmitters have both switched S1 and S2 as three-position sw ...
Surprised to hear that, guess I best open up r/c to confirm. Hate to have to send it away though. Thanks for the input.
Cheers
2015-1-3
rod
swmarwood@shaw. Posted at 2015-1-4 06:14
Surprised to hear that, guess I best open up r/c to confirm. Hate to have to send it away though.  ...
Sorry to hear that, the guys are right , this should be a 3 position switch.  But just for reference make sure you have read Gerry's posting on the switch functions.  You can only use S1 for RTH- not  s2. and you must be in NAZA mode for this function to work.
S2 only has two functions course lock and home lock.  Best of luck with this, keep us updated. (could it be that DJI have done away with the off position without telling anyone?)
2015-1-3
Gerry1124
Are both the s1 and s2 switches the same with only 2 positions?
2015-1-3
swmarwood
Gerry1124 Posted at 2015-1-4 07:10
Hi again. Just identified that both switches are identical inside r/c, so figured what the heck, i'll force the issue! Switch did not want to give in,but I won. Now after vigorous finger workout function is free. Confirmed this on app. and home lock now functional! All's well that ends well, thanks again.
Wayne
2015-1-3
Gerry1124
swmarwood@shaw. Posted at 2015-1-4 07:28
Hi again. Just identified that both switches are identical inside r/c, so figured what the heck, i ...
That's great,  Happy Flying!
2015-1-3
