NEED ADVICE ON WHY LIVE STREAMS ARE SUDDENLY FAILING
1173 9 2021-12-26
Aswo1
Have had succesful live streams from Mini2 at various locations. After latest updates to Galaxy S21 Ultra 5G device and the drone controller, all of my live streams are a mess. Specifically, the stream shows up on my Facebook group but the video is chopped and incomplete. I use Restream IO and have changed bit rates and resolution with no effect. I'm also lfying in same locations where I had previous succesful streams.  Any advice?
2021-12-26
Have you tried to stream using the the Fly app and the RTMP feature?
2021-12-27
MiniManiac
Flight distance : 1226368 ft
DAFlys Posted at 12-27 02:30
You cant LS to FB with the flyapp, you gotta use restream
2021-12-27
MiniManiac
I guess thats the answer, hence the term if it aint broke dont try to fix it.
2021-12-27
Aswo1
MiniManiac Posted at 12-27 10:25
I'm using Restream. Double-checked the RTMP URL and correct stream key settings but no joy.
2021-12-27
Facebook says it supports RTMP and the new Flyapp supports that.
2021-12-28
MiniManiac
DAFlys Posted at 12-28 01:44
Facebook is RTMPS only
rtmps://live-api-s.facebook.com:443/rtmp/
Which is why you need restream,io
2021-12-28
MiniManiac
Aswo1 Posted at 12-27 19:10
I wasnt replying to you mate, so your issue is probably your internet connection on the phone or device you are using to stream with.
Go home and test it on your home wifi and see if it improves if so thats the answer, if not then come back and let us know
2021-12-28
Hello there Aswo1. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try checking your internet connection if it is stable and try to do the said process on again for us to be able to isolate the said issue. Thank you.
2021-12-28
MiniManiac Posted at 12-28 05:36
Ah yes. I see they changed it a while back.
2021-12-29
