Advice
906 4 2021-12-1
djiuser_0iaggVY01Ezd
Flight distance : 9835407 ft
I have the dji fpv and Im a beginner that dont want to crash this drone learning fpv. So im looking for a fpv kit withe drone, remote and googles to learn with. I would rather something that works with the dji googles v2 but the i need a remote. So if anyone has some suggestions they would be greatly appreciated
2021-12-1
Depp
Flight distance : 1868796 ft
Hi. You need a drone with the DJI Air Unit (lite) or the Caddx Vista. These can be configured as a "PNP" that flies with the DJI FPV controller (around 300 $) or at an additional cost of maybe 10 to 30 $ with another transmitter. If you go that road (additional transmitter) you buy a different controller, not the DJI one, starting around 100 $.
I went the DJI road with a GepRC Cinelog 25 HD (which is great) but if I had to start again I'd go with the same drone but with TBS crossfire and a different controller.
Pro DJI: very easy to configure, pro non DJI: more options, a bit less expensive, in some cases more range/penetration. So if you lose video signal you probably still have radio signal and can push the drone up to maybe regain signal. Though I have to admit that I haven't flown with another controller yet.
There also is the possibility of getting an analog receiver for the DJI goggles. Then you can fly cheaper analog quads for practice. Haven't tried that either.
Good luck!
2021-12-1
Thank you so much for all the info,you have been so helpful but I have the v2 goggles so will they work with the geprc cinelog 25? I know the v1 will but I think the v2 are specifically for the fpv drone. Thanks in advance
2021-12-2
Hi there. Thank you for reaching out. Hope that you could get the best recommendation from our fellow DJI FPV pilots here in our community. Thank you for your valued support.
2021-12-2
djiuser_kLe4MikFjGlV
I am new to this as well and have found the motion controller to be really easy to use (It's the only remote I have used for actual flight so far).  I have been practicing with the regular remote in the virtual app which has been helpful as well.  I think it's pretty realistic.  Good luck!
2021-12-30
