Streaming to custom rtmp on iMac not working
1385 9 2022-3-8
djiuser_bQXK6cn4I216
Flight distance : 1002861 ft
I’ve been trying for a while to stream to a custom rtmp server with my dji mavic 3. The only things that I can get streamed it’s just a still image from the drone (first things the lens see).
I’m using an IPhone 13 pro and a MacBook Pro 16. I’ve tried to stream my GoPro to the custom rtmp and it worked fine, this seems to be a problem related with the drone.
Thanks in advance for your help,
Simone
2022-3-8
Ive used it to stream to YouTube and it worked great,  have you tried a different RTMP server.
2022-3-9
DAFlys Posted at 3-9 00:42
Thanks for your quick reply,
I’m following this video https://youtu.be/FnBZieDsLUc,
Should be the same for dji drones etc.
Can I change it with this procedure?
Do you have another way?
(It works with gopro)
Thanks in advance
2022-3-9
djiuser_bQXK6cn4I216 Posted at 3-9 01:21
I assume your on your wifi when you do that and not on 4g from your mobile.
2022-3-9
DAFlys Posted at 3-9 01:26
Yes pretty decent connection with starlink. I’ll try with an android device, and maybe windows when I have some time. Did you went live with a mavic 3?
2022-3-9
djiuser_bQXK6cn4I216 Posted at 3-9 01:31
Unless your port forwarding you need to be on the same network,  using starling would be unneeded.
2022-3-9
Antarctica
What do you mean? Sorry to ask again but, dis you used the mavic 3 for streaming?
2022-3-9
kopeck
I hate to bump an old thread, but I'm experiencing the same problem and was curious if you found a solution?
I've tried multiple computers, phones, and even RTMP servers.  The stream never gets past that single still image.  The audio gets works fine though.
K
2022-6-8
kopeck Posted at 6-8 08:40
My problem apparently was Starlink, if you have Starlink or maybe some other kind of satellite plan, that may be the problem.
You need open a port in your router, that is not possibile just with starlink modem, you need an ethernet adaptor ( if you have the square dish ), and another modem to work it.
2022-6-8
kopeck
Ah, this is all local on my part. So not *exactly* the same.
It's super frustrating, it just seems to work for everyone else.
K
2022-6-9
