Action 2 on FPV Drone
3370 5 2022-3-11
SentieriNatura
Flight distance : 7441824 ft
Hello,Using Action 2 4k 25fps with nd8 filter and with no filter.
Rocksteady stabilization ON.
The result is full of jello and poorly stabilized. What is going wrong ?
2022-3-11
Hi, there. Sorry for the inconvenience. It is not recommended that you install DJI Action 2 on DJI FPV for flying. Please try to use it in a normal situation to see whether the issue persists. Thanks for your understanding.
2022-3-11
Cobani
Flight distance : 612503 ft
Argentina
All of us have the same problem using Action 2 in FPV drone. Bad stabilization, glitches when you do 360° flips, vibrations... I'm still waiting the new firmware. There's no gyro data to stabilize in post with GyroFlow too.
GoPro have a really solid and error free hypersmooth stabilization, have reelsteady, you can use in GyroFlow too... I really need to fully switch to Action 2 because the weight, but I'm using GoPro because with this firmware it's unusable.
DJI could have the real sucessor of GoPro Session for FPV pilots, a game changer, but all this things turns a great camera into a potato and forces us to stick with GoPro until DJI fixes all the problems.
2022-3-11
Cobani
Argentina
DJI Thor Posted at 3-11 02:54
FPV drone it's not DJI FPV drone. We talk about fiber carbon REAL FPV quads.
2022-3-11
SentieriNatura
Cobani, thanks for your reply.
I was trying to use Action 2 for the weight. How much the GopRo reduces flight time  in comparison with Action 2 ?
Anyway, on the web I have seen many examples of using Action 2 with an FPV drone and the results seem not so bad. Mine tests are horrible...
Have you tried with different FPS ?
2022-3-11
Cobani Posted at 3-11 06:21
Hi, there. Could you please tell us whether the issue persists in the normal use situation? If yes, please give the original files for us to do a double-check. You could upload them to Google Drive/ Dropbox and send the link to us.
2022-3-13
