Tips for your flight safety~
13297 64 2022-2-20
DJI Support
Flight distance : 2408 ft
Hi DJI Pilots,
We've rounded up some coping tips for flight safety and we'd like to share them with you.
There are 4 parts, including the Environmental Considerations, Pre-flight Checklist, Precautions During Flight, and How to Find Your Drone. We hope this can help someone in need.
Part 1: Environmental Considerations
1. Only fly in environments that are clear of magnetic or radio interference, buildings, and other obstacles.
2. Do not fly above or near large crowds.
3. Only fly in authorized areas. Stay well away from GEO zones and restricted zones to prevent your drone from entering these zones by mistake and getting flyaway.
4. It is not recommended to fly your drone in scenic spots, historical sites, parks, and the vicinity of government and military institutions. Although these places are not officially demarcated as restricted zones, they are very likely to be controlled areas. The signal of the remote controller may be lost during the flight if you fly the drone in these areas, and the drone may unexpectedly fly away.
5. Do not fly the aircraft near areas with magnetic or radio interference, including Wi-Fi hotspots, routers, Bluetooth devices, high-voltage lines, large-scale power transmission stations, radar stations, mobile base stations, and broadcasting towers. Otherwise, the wireless transmission performance of the aircraft may be affected by interference, and the aircraft cannot fly normally.
Part 2: Pre-flight Checklist
1. Make sure that the remote controller and aircraft batteries are fully charged. (It is recommended to fully charge the battery and then fly the drone.)
2. Make sure that the propellers are mounted properly. Check whether the propellers are broken or bent, and whether all the propellers are unfolded.
3. Connect your mobile device to the remote controller. Power on the remote controller first and then power on the aircraft. Unfold the remote controller antennas and check whether the remote controller is linked with the aircraft. Check whether there are any warnings shown under Aircraft Status in the app, such as compass, IMU, or vision sensors error). Check whether the image transmission signal is strong at the takeoff point. When “Ready to Go” is shown on the app screen and a “HomePoint updated” prompt is displayed, enjoy your flight.
4. It is recommended to set “No RC Signal Action” to “RTH” under the remote controller Settings in the app. (The aircraft will automatically return to the Home Point when the remote controller signal is lost.)
5. It is recommended to set the RTH Altitude higher than the height of obstacles in the surrounding environment to avoid collisions during RTH.
Part 3: Precautions During Flight
1. Make sure that the antenna of the remote controller is aligned with the flight direction of the aircraft during flight, and pay attention to the image transmission signal strength. If a warning stating that the signal is weak or lost is displayed in the app, please try adjusting the antenna to make it pointed in the direction of the aircraft. Make sure that there are no obstacles between the remote controller and the aircraft. Otherwise, the signal may be lost.
2. If the image transmission signal is lost but the aircraft can be controlled, please try adjusting the antenna to make it pointed in the direction of the aircraft, and tap the map in the lower-left corner of the app screen to check the current position of the aircraft and real-time flight path. Then control the aircraft to fly back to the Home Point based on the flight path shown in the flight map. Please pay attention to the height of surrounding buildings and use the remote controller to control the aircraft’s speed and altitude to avoid collisions. If the signal between the drone and controller cannot be restored, please immediately press and hold the RTH button on the remote controller, and release the button until the remote controller makes beeping sounds (D-D-D). Go to the location of the Home Point recorded in the app and wait for the aircraft to return. (If the Home Point is updated during flight, please go to the updated Home Point.)
Part 4: How to Find Your Drone
1. If the drone fails to return to the Home Point, the 'Find My Drone' feature on the DJI app might just help you recover it. (In the map, the red arrow displays the last known location of the drone, and the blue arrow displays the user’s current position.) Tap the red arrow and the aircraft makes a beeping sound while repeatedly flashing lights. (Precondition: The aircraft is not powered off, and the remote controller and the aircraft are still connected.)
2. If the position of the drone recorded by the Find My Drone function is inaccurate due to a poor GPS signal, you can determine the coordinates and status of the flyaway drone by checking the flight records. If the position cannot be determined, contact DJI Support.
Tips:
1. If the position of the drone is determined, but the drone has fallen into water or a place that is difficult to reach (such as a tree, roof, or cliff), do not risk your personal safety to attempt to take it back.
2. DJI provides free flight data analysis service if your drone is under warranty to help you identify the cause of the accident.
2022-2-20
Frontliner 2020
Philippines
thank you for these tips and information...
2022-2-21
Good tips!
2022-2-21
DroneJunkieQc
Flight distance : 1015679 ft
Great tips. Especially the high tension power lines!
2022-2-21
dr6583
Flight distance : 490627 ft
Thank you for these great tips!
2022-2-21
DowntownRDB
Flight distance : 1722 ft
Thanks for sharing these great tips.
2022-2-21
Yaros1
Flight distance : 21307762 ft
Great info! Thanks for sharing!
2022-2-22
TonyPHX
Flight distance : 11229610 ft
Could you please publish this list as a series of pictures showing me how to do and do-not with a cartoon like quality?
2022-2-22
yogi053
Flight distance : 26104915 ft
Good advice and information.
2022-2-23
Bob-Mini-2
Flight distance : 73114 ft
Thank you for these guidelines, they are helpful.
2022-2-24
djiuser_Sgrln4rFxmkU
Hello, my drone can’t fly because a error in the gimbal unable to connect, so what should I do?!
2022-3-1
djiuser_Sgrln4rFxmkU Posted at 3-1 18:43
Hi there, sorry for the issue you encountered. Could you please tell us the exact model of your drone and provide us with a screenshot to check the error message? Please also tell us if the drone crashed or had a hard landing before the problem occurred?
2022-3-1
ro_flyer
Flight distance : 7557283 ft
Frontliner 2020 Posted at 2-21 01:22
2022-3-3
ReproRetro
Flight distance : 688652 ft
Excellent!
Thank you for this
2022-3-4
alexamary378
Pakistan
Is this you? If not, consider getting this one of your article at that site so that it can be reached to a wider audience. example
2022-3-5
djiuser_LOcjwbSfpYYt
Flight distance : 31339 ft
Jamaica
Thanks for the tips.
2022-3-6
ATKAS
Flight distance : 112303 ft
Really great info...thanks so much...
2022-3-8
akozc
Flight distance : 2019951 ft
even after flew nearly 300km,  still learning and  thanks for the tips
2022-3-9
djiuser_FDq85JfWKYxj
Thanks for the tips!
2022-3-21
Logheuger
Flight distance : 206017 ft
sorry whey ist is not in german too …
2022-3-22
fans16b03854
Flight distance : 21253 ft
Is there another sticky note for new owner checklist.
Do we need to register the drone somewhere?
Similar to above!
2022-3-22
Macked
Flight distance : 115364 ft
Registration depends on the drone you fly, how you fly, and where you fly.
2022-3-23
djiuser_xQj5E1tgxTit
youtube.com/channel/UCpiiTcFWw94lv8keAkmUxBg
2022-3-25
2022-3-25
djiuser_BjEcjH6s3GoI
Flight distance : 42858 ft
After deliberately destroying Mini2 with the updated firmware and removing the roll back function, you can go to hell. Stupid DJI
2022-3-26
Frontliner 2020
Philippines
you are welcome...
2022-3-26
djiuser_n49LgvSTyoqu
Looking for a camera ribbon part 1SLHH7800A0J0Z
Dji mini mavic if anyone could help thank you..?
2022-3-27
ro_flyer
2022-3-27
=lsquolsquo.sub.call.call{=lsquocons
goodgoodgoodgood
2022-3-28
goodgoodgoodgood
2022-3-28
HollandazePhoto
Thanks for the info
2022-4-2
djiuser_BYHRXKROLe9K
Flight distance : 25177 ft
thanks for the tips!
2022-4-4
dji-drones
Thanks for the excellent tips i ll flight safer now
2022-4-5
djiuser_1dPlsptMEKa5
Hi guys just got the se version and plugged both controller and drone with battery in on charge and the controller was half full so took about a hour till full,  but the battery in the drone is still flashing all 4 indicators and was wondering if I need to wake the battery somehow or is it ok as the battery for the drone takes longer?
Ps. Sorry for newbie question my first dji drone
2022-5-6
Evangeline
Yes. it is key to check to make sure before takeoff that the aircraft is pointed in the same direction as shown by the arrow on the map.
2022-5-12
Gonzacer
Flight distance : 1067854 ft
Mexico
Muchas gracias.
¿En qué número viene la solución cuando aparece la advertencia, "Comprobar el Estado de las Redundancias"? Soy usuario de Mavic 2 Pro
2022-5-15
Brooklyn355
2022-5-19
djiuser_GhH6SfaVIQKD
Turkey
This is what I need. Thanks for your advice
2022-5-31
djiuser_PEPblpWKaGTJ
No se me actualiza el firmware de vuela seguro en un mini 2 y por lo tanto me es imposible volar el dron. Que puedo hacer?
2022-6-12
SAADHERO
Flight distance : 2269905 ft
Kuwait
Great advices that all pilots should do
2022-6-12
