RONIN S FIRMWARE FAILURE
1908 5 2022-3-25
FATSO
HELLO
I am so frustrated right now with my Ronin S. I have been trying to update the firmware but it keeps on failing at 99 percent
then it says : Device gimbal (3) not connected
Gimbal is also not working
below is the log info (PLEASE HELP)
LOG
2022-03-26 07:21:32:684][info]
[general2-ws][ws-rsp] getAuthList success { auth_list:
   [ { id: 'account', status: 1 },
     { id: 'already_started', status: 1 },
     { id: 'improve_plan', status: 0 },
     { id: 'sn', status: 1 } ] }
[2022-03-26 07:21:32:745][info]
{"SEQ":"q8rg98hk","CMD":"get_auth_list"}
[2022-03-26 07:21:32:746][info]
{"ERROR":"success","SEQ":"q8rg98hk","VALUE":{"auth_list":[{"id":"account","status":1},{"id":"already_started","status":1},{"id":"improve_plan","status":0},{"id":"sn","status":1}]}}
[07:21:37.018][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: IMU(4:0)
[07:21:37.018][DJIDeviceInfoEnumera]  82% 14/17 IMU(0)
[07:21:37.018][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Pitch(4:1)
[07:21:37.018][DJIDeviceInfoEnumera]  88% 15/17 Pitch(1)
[07:21:37.018][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Roll(4:2)
[07:21:37.018][DJIDeviceInfoEnumera]  94% 16/17 Roll(2)
[07:21:37.018][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Yaw(4:3)
[07:21:37.018][DJIDeviceInfoEnumera] 100% 17/17 Yaw(3)
[07:21:37.018][DJIDeviceInfoEnumera] GCU            (5 :7) Ldr : 01.00.03.00 App : 01.00.06.68
[07:21:37.018][DJIDeviceInfoEnumera] IMU            (4 :0) device no reply, request timeout!
[07:21:37.018][DJIDeviceInfoEnumera] Pitch          (4 :1) device no reply, request timeout!
[07:21:37.018][DJIDeviceInfoEnumera] Roll           (4 :2) device no reply, request timeout!
[07:21:37.018][DJIDeviceInfoEnumera] Yaw            (4 :3) device no reply, request timeout!
[07:21:37.018][DJIDeviceInfoEnumera] Bluetooth      (7 :1) device no reply, request timeout!
[07:21:37.018][DJIDeviceInfoEnumera] Focus_Wheel    (6 :1) device no reply, request timeout!
[07:21:37.018][DJIDeviceInfoEnumera] LCD            (5 :6) device no reply, request timeout!
[07:21:37.018][DJIDeviceInfoEnumera] LCD_flash      (5 :3) device no reply, request timeout!
[07:21:37.019][DJIDeviceInfoEnumera] On-board Mount (5 :0) device no reply, request timeout!
[07:21:37.019][DJIDeviceInfoEnumera] Focus Handler  (5 :4) device no reply, request timeout!
[07:21:37.019][DJIDeviceInfoEnumera] RC Handler     (5 :5) device no reply, request timeout!
[07:21:37.019][DJIDeviceInfoEnumera] Battery        (11:0) Ldr : 00.00.00.01 App : 04.73.05.07   HG700BATTERY
[07:21:37.019][DJIDeviceInfoEnumera] EXT_GPS        (5 :1) device no reply, request timeout!
[07:21:37.019][DJIDeviceInfoEnumera] Focus Motor    (31:5) device no reply, request timeout!
[07:21:37.019][DJIDeviceInfoEnumera] Iris Motor     (31:6) device no reply, request timeout!
[07:21:37.019][DJIDeviceInfoEnumera] Zoom Motor     (31:7) device no reply, request timeout!
[07:21:37.019][DJIServerApi        ] [LinksLinks]url=https://mydjiflight.dji.com/links/links/hg700||productId=versionlistHG700
[2022-03-26 07:21:37:020][info]
[ws] event: { EVENT: 'firmware_refresh_progress', PROGRESS: 82 }
[upgrade-ws][ws-event]firmware_refresh_progress 82
[ws] event: { EVENT: 'firmware_refresh_progress', PROGRESS: 88 }
[2022-03-26 07:21:37:021][info]
[upgrade-ws][ws-event]firmware_refresh_progress 88
[ws] event: { EVENT: 'firmware_refresh_progress', PROGRESS: 94 }
[upgrade-ws][ws-event]firmware_refresh_progress 94
[ws] event: { EVENT: 'firmware_refresh_progress', PROGRESS: 100 }
[2022-03-26 07:21:37:022][info]
[upgrade-ws][ws-event]firmware_refresh_progress 100
[07:21:38.184][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[2022-03-26 07:21:48:173][info]
[ws] rsp: { ERROR: 'failure',
  ERROR_STEP_CODE: 1,
  ERROR_SUB_CODE: 0,
  ERROR_TYPE_CODE: 3,
  SEQ: '85ekrmhq' }
[2022-03-26 07:21:48:173][error]
[upgrade-ws][ws-rsp]refresh_upgrade_package_info failure { ERROR: 'failure',
  ERROR_STEP_CODE: 1,
  ERROR_SUB_CODE: 0,
  ERROR_TYPE_CODE: 3,
  SEQ: '85ekrmhq' }
[2022-03-26 07:21:52:919][info]
{"SEQ":"e3ouxpqx","CMD":"get_auth_list"}
[2022-03-26 07:21:52:920][info]
{"ERROR":"success","SEQ":"e3ouxpqx","VALUE":{"auth_list":[{"id":"account","status":1},{"id":"already_started","status":1},{"id":"improve_plan","status":0},{"id":"sn","status":1}]}}
2022-3-25
Hi, there. Sorry for the inconvenience. Please try to follow the steps below to troubleshoot:
1. Ensure the network connection is normal.
2. Ensure the assistant software used is the latest DJI Pro Assistant for Ronin.
3. Ensure the computer is properly connected to the Ronin-S.
4. Please disconnect the cable, restart the gimbal, and update the firmware with the gimbal powered on.
5. If it's convenient, please use another computer and cable and try again.
6. Remove the focus wheel and try to update again to see if it works.
2022-3-26
djiuser_4aRaoTaqqadv
DJI Thor Posted at 3-26 20:05
I can update with the Focus Wheel detached, but when I reattach the focus wheel it doesn't work. I can't seem to update my firmware with the focus wheel attached?
These are the last details of the firmware update before failing:
[2022-10-11 13:50:15:020][info]
[2022-10-11 13:50:19:960][info]
[ws] event: { EVENT: 'upgrade_package_progress',
  PACKAGE_VERSION: '2.4.1.30',
  PROGRESS: 99 }
[upgrade-ws][ws-event]upgrade_package_progress 99
[2022-10-11 13:50:19:969][info]
[ws] event: { ERROR_CODE: '0601080403', EVENT: 'upgrade_package_interrupt' }
[2022-10-11 13:50:19:970][info]
[upgrade-ws][ws-event]upgrade_package_interrupt { ERROR_CODE: '0601080403', EVENT: 'upgrade_package_interrupt' }
[2022-10-11 13:50:19:972][info]
[ws] event: { EVENT: 'upgrade_package_finish',
  RESULT: 'failure',
  error_step_code: 8,
  error_sub_code: 3,
  error_type_code: 4 }
[upgrade-ws][ws-event]upgrade_package_finish { EVENT: 'upgrade_package_finish',
  RESULT: 'failure',
  error_step_code: 8,
  error_sub_code: 3,
2022-10-11
djiuser_mFLQngrn62va
Finland
djiuser_4aRaoTaqqadv Posted at 10-11 09:54
Same thing here. Have you solved the problem?
2022-12-1
Xaulin
2023 and the problem still on... My Ronin S doesn't update the firmware, the joystick is not working and I haven't connection with my cell phone. YES, DJI, i've tryied many time to connect with a different USB ports, cables, everything and still not working. Seems that I'll need to go to another brand to get a gimbal that works properly.
2023-7-9
Hi, everyone. Aside from the steps above, you may also follow these steps:
1. Remove and attach the battery, and check whether the contact pins are damaged or not.
2. Check the display of the "About" - "Firmware Version" page in the Ronin application to see if the Ronin-S firmware version information can be displayed properly.
3. Restore the gimbal parameters of Ronin-S.
4. Refresh the firmware of Ronin-S.
If the issue persists after the above troubleshooting steps have been tried, please send the product back for testing.
Thank you for your kind understanding and support.
2023-7-10
