I've been thinking about the horizon
558 6 2022-4-30
No Original Thought
Flight distance : 1364275 ft
I am stood on a beach. Close enough to the waterline for it not to matter.
My feet are therefore at approximately sea level.
The horizon out to sea IS at sea level (as it is the sea!).
BUT the horizon appears to be higher than my feet.
If we assume a flat earth (don't go there - it's just for simplicity later on and actually works in our favour in this instance) then the illusion that the horizon is above the level of the sea at my feet is because my eyes are higher than my feet.
If I fly my drone out to sea a couple of hundredwtres and line it up with the horizon it will still be above the water, but by what amount?
If I set at about 20m high then flying out to sea the drone converges with the horizon at some point, but is still well above the water at 20m... That's also above my eye level... So that straight eye line to the horizon doesn't seem to work....
I can actually drop the drone below the horizon and it doesn't get wet... But is it lower than the height of my eyes at this point?
Assuming a flat earth the horizon is effectively at infinity (I think) so dropping my drone to the horizon line would only cause it to get wet if I was a long long long way away.
With a curved earth, the curve would take the water away from my drone way before infinity....
I need to stop thinking about the horizon now... It's making my head hurt.
2022-4-30
JJB*
Flight distance : 12717890 ft
We, people, are so different to each other.
When i am at the beach watching the horizon ; think of palm trees, bacardi cola and sexy woman....
But it`s making my hart hurt too
cheers
JJB
2022-5-1
No Original Thought
JJB* Posted at 5-1 00:01
This was a very different kind of beach!
2022-5-1
Bob-Mini-2
Flight distance : 73114 ft
IF, you wait long enough all the water will drain to the lowest parts - so - why worry, have a nice sandwich and beer.
2022-5-1
Macked
Flight distance : 115364 ft
Tilt your head to the right to get a fresh prospective.
2022-5-1
No Original Thought
Macked Posted at 5-1 11:02
Hey, you're right... I can go water skiing now!
2022-5-1
No Original Thought
Bob-Mini-2 Posted at 5-1 08:59
Mini 2 battery doesn't last that long, unfortunately.
I might need to wait for the Mini 3 Battery+
2022-5-1
