I am testing the Action 2 for situational shooting (IPSC), fixed on my baseball cap.
So far it worked just fine, but this weekend it produced some weird problems.
Since on the field I did not download and replay, so I figured only at home. Thus, no chance to change settings in order to figure, if it changes if I make another setting.
First, I found some muffled shots. where the shot sound is recorded, but too short (this might be the automatic sound level - my guess it is).
Second, I found some rumbling sound (like an earthquake) after the shot, later it became longer, and fill the void between shots and movements.
At the last stage, the sound is not in sync with the picture, it was a totally bad shot.
I made a video with the mentioned parts, could it be the processor not able to render all input because I used up all the processing power and bandwidth?
Or, the camera gave up?
I had audio problems too, different use case (roadbike) but huge problems nevertheless, my audio was constantly muffled and randomly went ok at times, very noticeable specially when vlogging there was times voice gets totally muted but the camera is literally in front of the face. Upload video sample, although I already showed it to DJI a month ago and may have improved the audio with a software update but I didn't test it out because I'm testing other problems too; it's not normal having to quality control test a camera that was launched last year.
Question 1 - was the wind noise reduction in use? This can sometimes be triggered by low frequency sounds, eg in a car, and that does strange things to the audio.
Hi there, we are sorry for any inconvenience. Could you please provide us with the original footage for a further check? You can upload them to your Dropbox or Google Drive and then send us the download link here.
DJI Mindy Posted at 5-10 00:07
Here you can find some raw footage, where you can hear the strange noises:
https://www.dropbox.com/sh/rafbjt5vrrk4zb4/AACjicieS166rR0gdsnSGiiWa?dl=0
download link
fansfe82067d Posted at 5-9 14:20
jabjab Posted at 5-10 02:08
download link
Thanks for the videos provided. We will forward them to our engineer for further check. If we get any update, we will get back to you asap.
I have tested again, with wind noise reduction OFF settings. The audio is TERRIBLE, there is a rumbling sound in between the shots as well. I am thinking that the camera mic gone bad, and will return the camera for exchange.
jabjab Posted at 5-14 08:02
Hi, there. Please kindly know that Action 2's radio will be optimized for audio in living/sporting environments, and can revenue tiny volume or noisy ambient sounds.
When the microphone sound pressure level of more than 140 decibels sound will exceed the hardware limits, resulting in such noise. If you adjust for sounds above 140 dB, you may lose the sensitivity of tiny trivial sounds.
DJI Gamora Posted at 5-17 01:44
Well, that is very unfortunate.
Especially that it was never mentioned in the manual, that I can't use it if the sound pressure level exceeds 140 decibels. I bought it for this specific task, now it is useless.
Not to mention the heating problem after 10 minutes of continuous runtime (which was not mentioned as well).
Can you please inform me how can I return the camera in exchange for the money I spent on it?
There is something here I don't get.
Can I adjust for the microfone sound level in the camera?
(That would be the only solution, since the problem is NOT the high sound level shots, but the VERY disturbing rumbling sound in between)
jabjab Posted at 5-17 04:22
I sent you a PM about this issue, could you please have a look?
SUKHOFPV Posted at 6-19 08:43
Hello, my Action 2 also has such a problem, you can tell me how to fix the sound on loud sounds, it has a very huge Noise sound
I wish I had the answer.
I sent the unit for repair, got it back (probably the same unit, since I foind my video on it), I had no way to test it yet. Also, did not recieve any comment on the problem…
