New Firmware for the Phantom 3 Series
28796 254 2015-12-22
david.p.mann
Flight distance : 18669501 ft
DJI-Ken Posted at 2015-12-22 12:15
Yes, for the first time when opening the app on IOS it may shut down. Deleting the app, power cyclin ...
My iPad Air 2 running IOS 9.2 started crashing out of the DJI GO app (version 2.4.3) EVERY time I tried to open camera page today. I tried powering OFF the iPad and powering back on but that didn't fix the problem.  My iPad Mini 3, however, is running fine.  Note: I have not yet updated my Phantom 3 or Inspire 1 to the 1.6 firmware.
Is there any way to fix this problem WITHOUT deleting the app (AND all its data - including videos) and reinstalling it?  I know I can get the flight logs back - because they are stored in the cloud, but I'm afraid deleting the app and reinstalling it will cause me to lose the numerous videos in the Library section of the DJI GO app.  Is there a way to restore these videos in the Library after reinstalling the app?
2015-12-22
Rob W
Flight distance : 96152 ft
Rob W Posted at 2015-12-22 15:29
Is the vibration issue fixed in this firmware? Can we fly safely?
@DJI
Is the vibration issues fixed in this firmware???? Please answer.
2015-12-23
dave-roberts.ou
Flight distance : 1214 ft
Rob W Posted at 2015-12-23 13:47
@DJI
Managed to get a flight today with the new firmware
Worked flawlessly
2015-12-23
Morph1
Banned
2015-12-23
EJSEJS
After this update I see in the Android DJI GO app by firmware 1.6.40 and by the remote controller 1.5.70, why not both 1.6.40 ??
2015-12-23
carloss66
Flight distance : 288671 ft
Arvs Posted at 2015-12-22 22:03
thanks for the info appreciate it, also is there a way for me to know that the update is done? lik ...
When the upgrade is in process the camera light flashes green and red. When the update is finished the sound the drone is making will change and the camera light will be green.
2015-12-23
GTDrone
Flight distance : 2197703 ft
Guatemala
How to update the software in each battery of the phantom 3 standard ??  i mean you can update the firmware just one time. but if you have more batteries how you are going to update the software on those batteries
2015-12-23
sploodge
Flight distance : 809350 ft
GTDrone Posted at 2015-12-23 17:14
How to update the software in each battery of the phantom 3 standard ??  i mean you can update the f ...
I believe the firmware is copied to the SD of the standard during update. So after the initial upgrade, remove one battery and add another then power on again, update should then be done to the battery, repeat for all batteries you have..
I don't have a Standard P3 but this is how I always thought the process would go for batteries.
2015-12-23
stu
Flight distance : 3675 ft
" In cold environments, propulsion output is automatically adjusted based on battery temperature and cell voltage. Horizontal and vertical speed is also decreased to avoid triggering battery protection"
Does any one know what temperature triggers the reduced power ?
2015-12-23
GTDrone
Guatemala
sploodge Posted at 2015-12-23 13:25
I believe the firmware is copied to the SD of the standard during update. So after the initial upg ...
Thats what you do with the DJI phantom 3 pro and advance but with the standard you cant do that . there no frimware donwnload in DJI page to download the firmware for the phantom 3 standard
2015-12-23
rene.vandermeer
Flight distance : 236781 ft
DJI-Ken Posted at 2015-12-22 20:06
I edited my previous post, the app will say 1.5.30+ after updating to 1.6. But the TXT file on the  ...
DJI -Ken,
Updating was a piece of cake.
The Apps gives the following versions:
App: 2.4.3
RC: 1.5.70
FW: 1.6.40
The results file:
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.06.0040.bin
Upgrading ...
Result: Success.
2015-12-23
DJI-Ken
Flight distance : 1515312 ft
That's great, it really isn't hard to do.
And as a note, the update will now say 1.6 and not 1.5+
Just make sure to update each battery too.
2015-12-23
sploodge
GTDrone Posted at 2015-12-23 20:18
Thats what you do with the DJI phantom 3 pro and advance but with the standard you cant do that .  ...
I know, I though the app transfers it to the SD of the P3S over wifi then  it does the firmware update ( unless it does it on the fly )..
2015-12-23
shane
Flight distance : 311988 ft
Just upgraded firmware to latest and now no GPS or IMU calibration function... apart from reinstalling previous firmware does anyone know alternative solution?
2015-12-23
lord.neo.gerson
Flight distance : 548212 ft
Chile
How can i reset the notification in the android app?
2015-12-23
davidrayplummer
DJI-Ken Posted at 2015-12-23 02:15
No mention of the RC Signal Loss since upgrading firmware last night. Several we're having the issue this morning. Mine still won't work after deleting and installing app, recalibration drone, power cycling everything and delinking RC. Any guidance?
2015-12-23
cbrenkus
Rebel Posted at 2015-12-22 23:03
Im staying put at 1.4. This issue with P3s falling from the sky didnt show up until 1.5.
Amen.. Same here
2015-12-23
DJI-Ken
davidrayplummer Posted at 2015-12-24 08:32
No mention of the RC Signal Loss since upgrading firmware last night. Several we're having the iss ...
I'm sorry your having issues, have you tried resetting the WiFi, here's a good tutorial video that explains it and relinking the aircraft.
2015-12-23
DJI-Ken
Sorry David, that's fro the Standard but I'll leave the video up if other Standard users are having problems.
2015-12-23
DJI-Ken
Tell me what exactly is happening.
2015-12-23
droidgabe
Thank you so much guys! I literally freaked out. I went for the update (purchased DJI Standard last week, been flying it successfully until new update prompted me today for the battery climate change) - After updating it some how just "Failed" at 64% and wanted me to force quit, did that and re-pushed the update as prompted followed by "Successful update" - after that my remote was getting NO signal to the aircraft. After troubleshooting I finally came across that video posted on how to re-sync the RC to AC, as well as resetting the WiFi password/name - which I did and now everything works GREAT with new update as well.
2015-12-23
evolicarus
i'll stick with 1.4 still...after i tried 1.5 and instantly had issues after a successful install, i went right back to 1.4...waste of 2 hrs during my day off... until i know 120% sure that 1.6 is legit with no issues i'll stick to the motto "if its not broken, don't fix it" attitude
2015-12-23
DronesInPhuket
DJI - you need to learn how to treat customers and differentiate between software and hardware issues: http://forum.dji.com/thread-37786-1-1.html
2015-12-23
DJI-Ken
droidgabe@gmail Posted at 2015-12-24 11:32
Thank you so much guys! I literally freaked out. I went for the update (purchased DJI Standard last  ...
That Youtube tutorial video of the resetting WiFi and re-linking the R/C to Phantom is also located in the DJI GO app
2015-12-23
phantom3.nikola
Hey guys, so I was updating my phantom and I turned it off accidentally and after that remote unconnected from the phantom and the phantom stared making really loud noise bip bip bip...... After the remote started biping as well ! I don't know what to do ! And I'm really scared
2015-12-24
phantom3.nikola
2015-12-24
dave-roberts.ou
phantom3.nikola Posted at 2015-12-24 09:03
Hey guys, so I was updating my phantom and I turned it off accidentally and after that remote unconn ...
Just let it beep away it will sort it self out,it may take 10 minutes or so
So stick it in another room because those are loud beeps
2015-12-24
phantom3.nikola
2015-12-24
davidrayplummer
DJI-Ken Posted at 2015-12-24 09:38
Bought Phantom 3 Standard about a week ago from Best Buy. Flew it a handful of times, no problems. Loved it. On Tuesday night, got a notification on the app that there was a new firmware upgrade. Updated and all seemed fine. Took it out to fly and there was a red notification on the app that said: "RC Signal Lost." Wouldn't fly. Rebooted everything. Deleted the app. Re-installed the app. Calibrated the compass. Relinked the RC. Rebooted everything again and still have the "RC Signal Lost" error. Phantom 3 flashes 2 yellow lights.
2015-12-24
Morph1
Banned
2015-12-24
nigelwilkins
Flight distance : 518084 ft
If the controller's on the latest firmware you can't do anything to it, only the bird.
2015-12-24
Rob W
DJI-Ken Posted at 2015-12-23 05:26
Totally up to you, 1.5 addressed batteries issues as well as 1.6
DJI, Why can't you answer the most important question here? Does this firmware fix the vibration issues or not?
2015-12-24
phantom3.nikola
2015-12-24
pjefferies
Flight distance : 1068002 ft
I updated to 1.6 this morning.  Took about  very straightforward.  Test flight after was fine - really didn't notice any changes (it is very warm here).  [img]https://forum44.djicdn.com/data/attachment/forum/ [/img]
2015-12-24
phantom3.nikola
2015-12-24
Barney Rubbel
DJI-Ken Posted at 2015-12-22 22:26
Thanks for all the help Ken. Do I need to run this update with each of my batteries installed?
2015-12-24
nicwilson
nigelwilkins Posted at 2015-12-23 01:04
I'll not be trying it until it's verified, since there's no return to 1.4 if it doesn't fix the vi ...
Ok, somebody want to elaborate?  I have just come back from overseas with over 100 flights on 153 and have no idea about any vibration?  The firmware has been rock solid for me so this cannot be an generic across the board issue?
2015-12-24
nicwilson
Swedrone Posted at 2015-12-23 02:17
Seem there is finally a 2.7 K option available on the Professional
Question is why would you want it?
2015-12-24
nicwilson
Sailor P3 Posted at 2015-12-23 12:20
I must be one very lucky guy.
Bought the P3P last June.
Yup I agree with you I have had the same faultless experience with hundreds of flights now.  I mainly keep three things in mind,  1.  I don't fix things that are not broken and 2. I don't go at things like a bull at a gate but take my time,  3.  as my Son is an aircraft jet engine tech,  he made sure from day one that I do a full flight inspection before taking off.     A flawless amazing product that has totally changed my view on photography merged with a flying hobby.
2015-12-24
deni691
When attempting to update I get continual very loud beeps.   Have no idea how to stop this.
2015-12-24
