What Android software to use with original Air (1)?
1030 18 2022-5-8
Dangerly
I just dusted off my old Air 1 and it seems like everything is still working, except I don't know what software to use for my Android. Is there any software that works on an Android to fly the original Air 1?
2022-5-8
Hi there. Thank you for reaching out. We're glad that you again setting up your DJI Mavic Air. You may access the link below for you to download the app dedicated to the said drone. Hope this helps. Thank you for your valued support.
https://www.dji.com/downloads/djiapp/dji-go-4
2022-5-8
me0Max
DJI Paladin Posted at 5-8 17:26
DJI GO 4 - V 4.3.46 not working on Samsung S22, crashing after press "Go Fly"  ( (on S21 Working...)
2022-5-22
me0Max Posted at 5-22 11:11
Can you please try to uninstall and reinstall the app to see if the issue persists?
2022-5-25
JJB*
Flight distance : 12566335 ft
I use an old device running on Android 7.1.1   Go4 app and FlyApp both work great.
2022-5-25
me0Max
DJI Paladin Posted at 5-25 03:32
Removing the app didn't fix the issue. On other devices, S22 + and S22 Ultra, the situation is the same, apparently the problem is in the Exynos processor. I will wait for the next version of the application. (Firmware: S906BXXS2AVDB)
2022-5-25
me0Max Posted at 5-25 09:18
Thank you for your response. As per checking here, it seems that the mobile device is not listed on our compatible device and this might be the main cause of the issue. Kindly please refer to the link that I sent above for you to check the list of compatible devices. Thank you for your understanding and support.
2022-5-31
djiuser_JE5Ldr0k3Fy7
Is there plans to upgrade the software so it will work with the Samsung S21?   It used to work on my S21, but with the latest Android update it doesn’t work anymore.
2022-6-2
me0Max
DJI Paladin Posted at 5-31 05:08
Your link says that the latest supported Samsung device is the Galaxy S9+, this phone was released in 2018, after it came out S10, S20, S21, and this year S22
2022-6-5
me0Max Posted at 6-5 15:07
Thank you for your response. That would be the current list of compatible devices for the DJI Go 4 app. Thank you for your understanding and support.
2022-6-12
Blériot53
Flight distance : 6260935 ft
It's Android version 12 that killed the DJI Go4 App.  It won't even load now. You might consider the paid App Litchi.  It runs on any Android device and works with a whole series of DJI Drones including the Air One.  No hassle, just works. I've used it trouble-free for the better part of 5 years. As well as the DJI Apps, of course.
2022-6-12
Sean-bumble-bee
Flight distance : 15997 ft
Blériot53 Posted at 6-12 04:40.......Litchi.  It runs on any Android device and works with a whole series of DJI Drones including the Air One.  No hassle, just works. I've used it trouble-free for the better part of 5 years. As well as the DJI Apps, of course.
Bleriot53, does Litchi record DAT flight logs, if so where does it store them?
Also does it record a txt flight log? If so under what circumstances does it do that? I generally down load flight logs in batches and then rename them in accordance with my interest in them, somehow I seem to have got txt flight logs labeled as from Litchi and I now wondering if this is correct.
From what I can NOW see Litchi does not record a txt, rather it records a limited csv.
2022-6-12
Blériot53
Sean-bumble-bee Posted at 6-12 05:16
As a Litchi user you get a FREE (limited) account with AIRDATA UAV, to which all data can be uploaded. This is what I do.  I've never had recourse to download a flight log.  If the data is in CSV, I believe it's possible to convert those values to text seperately.
2022-6-12
Sean-bumble-bee
Blériot53 Posted at 6-12 05:32
Ah ok and thanks.
2022-6-12
Blériot53
You're welcome.
Here's a link for conversion from CVS to TXT online.
https://convertio.co/csv-txt/
2022-6-12
Sean-bumble-bee
Blériot53 Posted at 6-12 06:25
You're welcome.
It is actually the csv's I want but I am just 'wondering' where I got these txt's from lol.
I process the csv's with some DIY software (needs Linux) to create my 'pilot's log book'.
2022-6-12
Blériot53
Sean-bumble-bee Posted at 6-12 06:41
It's some time since I used Linux (Ubuntu flavour) on my main PC.   Been back on Windoze since version 10.
2022-6-12
fans4d2ef7d0
Even after perusing these comments, and trying all of the suggestions (except paying for Litchi) i cannot get Go4 app to work on my Samsung S21...wtf?
2022-6-25
Dangerly
fans4d2ef7d0 Posted at 6-25 17:26
Bottom line: DJI has abandoned the Air 1. I couldn't get it to work either. Wondering how long before my Air 2 doesn't work any more.
2022-7-2
