sbonev
Flight distance : 3665279 ft
Bussty Posted at 7-11 16:05
The latest version of PTGUI seems happy to accept both vertical and horizontal images it actually says in the Project Manager window that you have both types in the stitch so my method is...
Take the best manual reading I can work out and lock down manual exposure using that.
thanks, i am using Panorama Studio recently, comparing to some of the results with older versions of ptgui the results were a bit better, especially for correctly placing images using metadata and water images stitching. not sure how will the newest version of ptgui will be, have to check that.
as for the vertical shots i usualy do 2 raws of shots for just in case better control points alignment. but i will try your process with only 8 shots at 60 degrees vertical. i do the sky last. but in any way the sky and water are usually difficult to process. |
