No course lock Rth
958 16 2022-8-7
dronie1965
Flight distance : 24971795 ft
It is a pity that when pressing rth you can’t do a kind of
Course lock like you can do with the mini 2.
Hope dji will implement it with a fw update
2022-8-7
Flight distance : 10186312 ft
It is a really nice feature, should be reinstated ;+)…
2022-8-7
The Saint
Flight distance : 6260171 ft
my guess is this was unintentional and essentially a "bug" in the mini2 and therefore they didn't know to repeat this in the mini3pro.  the real answer is simply to implement "course lock" as a feature.  likely this has suffered that same fate as waypoints.
2022-8-7
DowntownRDB
Flight distance : 1722 ft
It would be a useful feature.  Hopefully, DJI will consider adding it for the Mini 3.
2022-8-7
StevenQX
Flight distance : 287474 ft
Yes, it has always been a nice feature. No reason to remove it...
2022-8-7
Hello there dronie1965. Good day and thank you for reaching out. I will forward these matter and information to the designated DJI Department for attention. Thank you.
2022-8-7
Flight distance : 2354357 ft
Dirty Bird Posted at 8-7 17:28
This worked on models without obstacle avoidance, & on OA models when OA is disabled.  Makes sense the drone has to fly forward when using the OA sensors.  I forgot to test if disabling OA on the Mini 3 allows rotation during RTH, but give it a try.  This works on a Mavic Pro, Mavic 2, & the P4/P4P 2.0.  I don't have any newer OA birds to test besides the Mini 3.
Thats a good point DB, i forgot to check this myself yesterday when testing a bit more, *face palm*
2022-8-7
+1 great suggestion
2022-8-7
dronie1965
I always fly without oa , therefore doesnt work unfortunately
2022-8-8
Goggles Pisano
Flight distance : 8810745 ft
If you turn Obstacle Avoidance off and hit RTH it automatically turns the OA back on and locks you out from disabling it again. It does not allow rotation during RTH but you can rotate when ascending or descending though ....
2022-8-8
Sean-bumble-bee
Flight distance : 15997 ft
Good catch
2022-8-8
Goggles Pisano
Dirty Bird Posted at 8-8 07:29
Some of the changes they made on the newer birds are undesirable.   Inability to disable OA during RTH & not stopping ascent during RTH climb when bumping throttle down both come to mind.
I'm assuming you can stop the ascent with pause button, I hope ??
2022-8-8
So if the OA is turned off manually for the flight, does it then auto turn on when RTH is initiated?
That should be users choice, it could mean that the drone may not reach home if the battery was low, granted, it shouldnt be drained so low but it happens, that's nearly as bad as the 3-second RTH after disconnect. you get no time to try to adjust the RC
2022-8-8
Goggles Pisano
Bashy Posted at 8-8 20:55
Yes. it turns back on even if it is set to off before RTH . You are unable to turn back off during RTH unless you abort the RTH
2022-8-9
Goggles Pisano Posted at 8-9 14:20
Thats a shame, its ruined a great feature that the Mini 2 has
I get why OA is needed for RTH but surely it should be an option.
There should be a PRO mode whereby pilots that have done x amount of miles/kilometers can enable this mode and should be able to disable certain features that DJI deems as part of their safety. We don't all need to wear kid gloves.
2022-8-9
Dirty Bird Posted at 8-9 14:06
Haven't flown the Mini 3 enough to know for certain, but that's what I'm gathering from what others are posting.
Thanks, it certainly looks that way
2022-8-9
That would be nice indeed.
Although I feel it was a 'undocumented' feature that DJI converted as 'nice feature'
2022-8-19
