InspektorGadjet
Flight distance : 439915 ft
Ray-CubeAce Posted at 12-8 12:26
DSLRs and other digital cameras have non replaceable batteries inside them as well to keep settings in memory. They have to be replaced by manufacturers as well. The Osmo Pocket's battery can be replaced. If you are running a car that old on a regular basis not only is it more polluting but relative fuel consumption would horrendous. Most older cars are also not as good at protecting their passengers or pedestrians compared to newer models. You would not get an old car through modern safety testing. Even old synthesizers need replacement parts as the older analog circuits rely on capacitors and resisters that change value over time. Some of those components get increasingly expensive over time to replace.
All you are doing is slowing your own progress, you halt nothing. Your car is depleting fuel faster with less efficiency than a newer one. How is that saving anything?
Please don't get me wrong. If you prefer to hang onto older equipment. that's fine by me, just don't go on about it being horrendous. There is nothing keeping you from hanging on to your Osmo Pocket. LEDs are more efficient than incandescent light-bulbs, Modern engines are more efficient than older ones, Modern electrics and electronics uses less energy for a given task then older generation models of equal use. Old things are not necessarily obsolete but often more dangerous or less efficient if not kept in good order. Keeping them in good order gets progressively more expensive as parts become harder to obtain. Some older examples of all things in good order should be kept as a record of progress but for little else.
People are so judgemental, my car is not old, it was purchased new in 2006, just had a lot of use.
An Osmo pocket with some good use will see the battery in bad shape after 2-3 years.
DSLR's have all replaceable batteries.
Memory batteries are nor what we are discussing here, and I change those myself in every piece of equipment I had to.
I'm not atacking DJI here, sorry if I hurt some people feelings who love them so much.
My mavic mini has 3 batteries. Planning to get more.
My GoPro has 3 batteries.
My DSLR has 4 batteries.
My sound recorder uses AA batteries.
When I'm on the field I want to have more batteries than needed. That's why I said I find it odd, and is stopping me from getting it. Thanks everyone for the input.
