Props compared
515 13 2022-11-20
Elephant Apocalypse
Flight distance : 6336594 ft
From testing, the 4 blades seems to give the most initial take off thrust, with the 5 blade or stock with same amount of throttle you barely lift off but given the prop wash the drone drifts quick also 4 blades are better in performance however its only perk so far is noise louder but not an issue unless its flying around you all day
Contenders
Contenders
2022-11-20
Elephant Apocalypse
2022-11-20
Elendil
Flight distance : 458904 ft
Philippines
cool comparison bro, did you experience any tumbling issues with the chopped prop guard with 4 blade props?
2022-11-20
Elephant Apocalypse
with 5 blades, no tumble on either, 4 blade is definitely awkward 5 blade is smooth
2022-11-20
Elephant Apocalypse
A pleasant surprise reception seems to be better, near the rocks on my stock setup it would drop to 25mbit today was 50mbit all the way
2022-11-20
Elephant Apocalypse
important: calibrate IMU and compass, gimbal
2022-11-20
OnePixel
Flight distance : 45049 ft
Interesting, thanks.
I'd like to know if the battery consumption increases or decreases.
2022-11-20
Elephant Apocalypse
OnePixel Posted at 11-20 22:46
same if not improved, lighter drone
2022-11-21
DowntownRDB
Flight distance : 1722 ft
Elephant Apocalypse Posted at 11-20 21:31
https://www.youtube.com/watch?v=pbnIxfkJR2w
Excellent comparison.  Thanks for sharing.
2022-11-21
Elephant Apocalypse
Just got done with a range and flight test,
Definitely longer battery life, flew close to 4 mins and was 40% left , no tumble for sure better reception even past areas that often straight cut off on my FPV drone, avata stock definitely fall short, now with mods and setup no limits except battery  limit.  Gimbal was 38-40%
2022-11-21
Elephant Apocalypse
2022-11-21
JAMh
Flight distance : 4754715 ft
Mexico
Elephant Apocalypse Posted at 11-20 21:40
why?
It's not working without it or just for security?
2022-11-24
Elephant Apocalypse
JAMh Posted at 11-24 10:18
why?
Stability you are in essence modifying aerodynamics
2022-11-24
JAMh
Mexico
Elephant Apocalypse Posted at 11-24 11:43
THX
I will be testing tomorrow
I guess orange and blues are the same angle, as I have both
2022-11-24
